Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Just bought a Corbeau seat and rollcage......what harness to get??????
Old Feb 9, 2002 | 10:49 PM
Halo's Avatar
Default Just bought a Corbeau seat and rollcage......what harness to get??????
I did a search but ended up more confused. I have a 97 Civic hatch with an Autopower 4 point race bar and Corbeau Forza 2 seat....I figured choosing a harness would be a no brainer....but I am more confused than ever.....What type of harness to get for street?4point.....5point...6 point? Roll bar mount? Individual? Roll bar?etc..etc Also I have heard that harnesses are illegal for highway use? I don't need anything fancy.....just something that will keep me safe if the crap hits the fan
Old Feb 9, 2002 | 10:58 PM
Halo's Avatar
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (Lil Cs Zc)
yeah I like that also, but I ma hearing that 4 points tend to submarine? I know nothing about harness's which is why I ask.........what about this design http://www.racerwholesale.com/Mercha...Code=Harnesses
[Modified by Halo, 12:01 AM 2/10/2002]
Old Feb 10, 2002 | 07:42 AM
travis's Avatar
As cheap as the RacerWholesale deal is, I'm amazed people buy anthing else! I believe it's still $109 for any Sabelt/Sparco harness you want. My personal choice would be a 5 point with clip-in lap and sub belt, or 6 point with clip-in lap and bolt-in sub belt, both with the wrap-around shoulder belts for the roll bar.
Here's a pic:
*edit* woohoo, 1000 posts!
[Modified by ITR#231, 9:44 AM 2/10/2002]
Old Feb 10, 2002 | 07:58 AM
GRM Scott's Avatar
25 Year Member
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (ITR#231)
I second the SABELT from Racerwholesale, i just put a pair in my car, and they are fantastic. I'd highly recommend getting a five point camlock, because you dont' HAVE to use the 5th point, but you'll have it when you really should use it (track etc). It's not at all uncomfortable if you fit everything properly. I've got a detailed install (for an integra, anway) up at http://www.sandmracing.com/ssabelt.html
Old Feb 10, 2002 | 04:26 PM
Civic242's Avatar
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (Aleph)
I second the SABELT...........
Worth a thousand words.
Old Feb 10, 2002 | 04:34 PM
civicrr's Avatar
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (Civic242)
Get a 5 point. There is a tendency to tighten the shoulders too much with a 4 point. That causes the sub. problem. There are some driving groups that won't let you on track with the 4 point. If you don't have a lot of bucks for it, get a latch & link style. It is a little more work to belt in, though. You are right. It isn't legal to use the harness (any) in many states unless it had goverment approval. Check out the link that Aleph gave you. He details a nice install. He has both his harness & oem belt. I used to run a similar system when I had a street/track car. I used to buckle up the harness & put it behind the seat when I wasn't using it. Helps to keep things from smacking you in the head.
Old Feb 10, 2002 | 04:49 PM
Chris's Avatar
I got 2 of the Racer Wholesale Sabelt 5 point CAMLOCK harnesses for $109 each... now Im just waiting on the Autopower!
Old Feb 10, 2002 | 06:22 PM
Drew M's Avatar
New User
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (Halo)
As some have mentioned, a 4 point is not a real good idea. A crash can result in injury from the lapbelt breaking ribs etc. Go with a 5 or 6 point. You won't be wearing the harness on the street anyway. If you can move enough to merge and headcheck then the belts are too loose to be worthwhile.
Stay away from those rally/street hybrid belts. They are pricey and IMO are not as effective as the 3" restraint systems such as the Sabelts.
Old Feb 11, 2002 | 08:47 AM
eight-six's Avatar
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (Cobra)
Sabelts are your best bet, very good for the money. I think I spent $116 for the 5pt h-style from racerwholesale.
Old Feb 11, 2002 | 09:42 AM
ITC Racer's Avatar
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (JAC-GSR99)
I would recommend the Simpson Camlock setup. The webbing seems to be thicker than most that I have seen and the 3" shoulder and lapbelt distribute the tension across the body better, IMHO. Camlock is nice since each belt plugs in separately.
Definitely get the 5 or 6 point setup also to keep from anti-submarining and to keep the lap belts from riding up when you tighten the shoulder belts.
I have not seen any aftermarket harnesses that are street legal due, I believe, to the different mounting options available.
Old Feb 11, 2002 | 10:26 AM
r2x's Avatar
r2x
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (ITC Racer)
5 or 6 point harness and be sure to mount it properly since an improperly mounted harness will hurt you far more thanit will help you
BUT MAKE SURE YOU Check the laws in your state. It is my understanding that MOST racing harnesses are not street legal. Not becuase they aren't as good as a stock belt, but because the companies don't want to pay for the certification test.
Old Feb 11, 2002 | 10:31 AM
Drew M's Avatar
New User
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (r2x)
Actually it is because the government has no way of regulating how the individual installs the belts. Stock belts are installed to structure that is speced out by the government. The government can't dictate how Eugene mounts them in his Nova. He could use sheet metal screws through the webbing and no one would know until Eugene is kissing his hood with his feet stuck on his steering wheel. The easiest way to control this is not allow them in the first place.
Old Feb 11, 2002 | 11:01 AM
urbanlegend21's Avatar
New User
In VA you can have your setup individually inspected and certified by a VDOT official
Old Feb 11, 2002 | 11:06 AM
Drew M's Avatar
New User
Default Re: Just bought a Corbeau seat and rollcage......what harness to get?????? (urbanlegend21)
Well the guy isn't from VA so I don't think that is applicable to him . . .
Old Feb 11, 2002 | 11:13 AM
New User
just throwing an idea to look for out there
jdmfreak1992
Honda Civic (2001 - 2005)
Jun 29, 2012 02:01 PM
em2ssm02
11
Mar 17, 2007 07:54 PM
AntMan401
Aug 22, 2006 04:04 PM
Pythagoras
17
Sep 3, 2004 07:23 AM
