B20vtec...Cutting Valve relief and Cam options.
Old Jun 8, 2005 | 07:26 PM
TurboJesse
Guest
Posts: n/a
Default B20vtec...Cutting Valve relief and Cam options.
setup in my daily driver is a stock b20 vtec with b20b block and 2nd gen b16 head. Looking for more power so I plan to build a custom header, cut and port an ITR intake manifold and upgrade the cams (ITR/CTR maybe BC 3+'s)
Ive "heard" that run any cam larger than stock requires cutting of the valve reliefs. if anyone can give me some more info on this (maybe a definate answer on if ITR/CTR cams will work WITHOUT cutting the reliefs) and how exactly they went about cutting the reliefs that would be great..
sorry for the newbie questions...Im new to the all motor world
Old Jun 8, 2005 | 07:38 PM
The Destroyer's Avatar
Default Re: B20vtec...Cutting Valve relief and Cam options. (PhoenixTurboJesse)
Not to bad an *** but it doesnt really make sense to run big cams on a low compression motor, and one that doesnt rev high safely.
Personally id go ahead and make the header and do all the other bolts-ons if you dont want to touch the block.
Ill let others chime in, cause as of right now im bench racing.
Old Jun 8, 2005 | 07:44 PM
TurboJesse
Guest
Posts: n/a
i'd like to be able to run ITR/CTR...nothing bigger..
Professor15's Avatar
I wouldnt recomend cutting valve reliefs because there is a possibility of you cutting uneven amounts on each pistons, throwing your rotating assembly out of whack. But im sure that you would be able to rum some mild cams like CTR/ITR or BC3's on stock block without having pistons to valve contact...if your going to build a header...why not take the time n clay the motor? lol
Old Jun 8, 2005 | 08:04 PM
TurboJesse
Guest
Posts: n/a
Default Re: (drchulo)
i'd really like to get away with being able to just throw some cams in and not pull the head.
im just buildign the header for the hell of it
Old Jun 8, 2005 | 09:15 PM
EG6R's Avatar
Mine is a stock B20b block with GSR head. Im not sure if running typer cams will be a problem without cutting the valve reliefs but I run s2s2 cams and i had to modify the valve pockets wich was done by a machine shop. HTH
Old Jun 8, 2005 | 10:10 PM
GradyDC5's Avatar
Well, I have a stock b20 bottom end with the arp bolts and ge head studs. Gsr head with 01 itr cams. I basically took a circular saw the size of the valve relief, and englarged then my self by eye. I have not had any ill effects from this, and my motor with basic bolt ons made 185 and 144. Hope that helps you
Old Jun 9, 2005 | 07:11 AM
TurboJesse
Guest
Posts: n/a
Default Re: (ReallySlowEg)
bump for more info
Old Jun 9, 2005 | 12:57 PM
1.8u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallySlowEg &raquo;</TD></TR><TR><TD CLASS="quote">Well, I have a stock b20 bottom end with the arp bolts and ge head studs. Gsr head with 01 itr cams. I basically took a circular saw the size of the valve relief, and englarged then my self by eye. I have not had any ill effects from this, and my motor with basic bolt ons made 185 and 144. Hope that helps you</TD></TR></TABLE>
Thats kickass.
Here I found this. https://honda-tech.com/zerothread?id=1263261
qais_vtec
Sep 4, 2018 10:42 PM
crazihobo
Oct 12, 2011 02:48 PM
egjdmcivichatch
Mar 30, 2011 01:54 AM
ex96vtec
Mar 2, 2009 12:10 PM
function83
Jun 30, 2003 02:58 AM
