obd2 to obd 1 conversion question
Old Jun 8, 2005 | 07:05 PM
integGSR805's Avatar
Default obd2 to obd 1 conversion question
i have a 96 gsr planning on converting my OBD II to OBD I for tunning purposes but mainly do i need to do anymore than getting the conversion harness and an OBD I ECU?
Old Jun 8, 2005 | 07:36 PM
iH8RICERZ's Avatar
Default Re: obd2 to obd 1 conversion question (integGSR805)
thats all you need..be sure you order the obd2A-1 (version A or Version 1) conversion harness.
Old Jun 8, 2005 | 07:57 PM
cool thanks. thats what i thought but just wanted to make sure. getting a harness off of boomslang fabrication $74 shipped
Old Jun 8, 2005 | 08:05 PM
Gant's Avatar
what ecu are u going to run.
boomslang :thumbsup:
im using there 0-1 conversion harness on my hatch good stuff
Old Jun 8, 2005 | 08:24 PM
HARI.'s Avatar
Default Re: (Ba4)
you're also going to need to change your distributor to obd1 since you are running an obd1 ecu
Old Jun 8, 2005 | 08:44 PM
gsrious's Avatar
no you don't... it's all plug in play
Old Jun 8, 2005 | 09:04 PM
DragSource's Avatar
Yes, that's handled in the harness. . .
That's a bad rumor that got started long ago - I was misinformed on that for a long time myself.
Old Jun 8, 2005 | 09:20 PM
HARI.'s Avatar
Default Re: (DragSource)
i guess you have to rewire the distributor, rather than replacing it with an obd1. here's the chart on how to rewire obd2 distributor to obd1
Old Jun 8, 2005 | 09:54 PM
iH8RICERZ's Avatar
You do not need to do that.... all you really need is the correct version obd2-1 conversion harness and an obd1 ecu thats right for your motor/mods. Its plug and play....as for doing the obd0-1 conversion, there's more involved.
Old Jun 8, 2005 | 10:54 PM
Default Re: (Ba4)
im planning on running a JDM p72 with uberdata im buying it off my friend
Old Jun 9, 2005 | 08:53 PM
ALI BOULALA 2's Avatar
nice da 19.....
Old Jun 16, 2005 | 10:01 PM
got the ecu in and everything currently running the old set up my friend was running but retuning it next week rev limits at 8500 pretty much stock internals except for type r lost motion assem.
Old Jun 17, 2005 | 01:14 AM
fergy016's Avatar
my 98 gsr (obd2a) to obd1 harness worked great.
make sure if your running a stock intake manifold that the polarity to the vtec solenoid is reversed.
Old Jun 19, 2005 | 01:28 AM
Default Re: (fergy016)
i changed the stock IM to the Skunk 2
Luke_CD5
Nov 23, 2019 02:37 PM
Max500
Aug 5, 2010 05:26 PM
jo7man4
Jun 15, 2009 11:33 AM
gonmaro
Sep 13, 2008 03:05 AM
Got-VTEC
Jun 2, 2002 08:41 AM
