eagle rods in a D16 how much do you need to grind
Old Jun 8, 2005 | 05:06 PM
brusk13's Avatar
Default eagle rods in a D16 how much do you need to grind
Ok machine shop called me yesterday and said that the eagle rods i was having put in hit the bottom side of the cylinder. I told him to grind it. He called me back and said he thought it was to much to grind. How much do you have to grind off should i be concerned with this or tell him to grind away and not be worried.
Old Jun 8, 2005 | 05:19 PM
Fobtions's Avatar
Default Re: eagle rods in a D16 how much do you need to grind (brusk13)
notch it like this, refer to this site for more details http://www.theoldone.com/artic...tips/
Old Jun 8, 2005 | 05:39 PM
hatchblack's Avatar
Default Re: eagle rods in a D16 how much do you need to grind (Fobtions)
why would the eagle rods be hitting the block? are they the correct block for the rods? i don't see why you would have to cut anything out of the block to make them fit.
Old Jun 8, 2005 | 05:43 PM
93formula's Avatar
Default Re: eagle rods in a D16 how much do you need to grind (hatchblack)
the eagle h beams need clearancing of the block.
i think there is one company that makes d series rods that clears the block, cant remember right now, crower??
Old Jun 8, 2005 | 08:36 PM
NastyHabitzCRX's Avatar
the newer eagles dont have to have the block notched at all.
vtechjunkie
Dec 7, 2008 01:00 PM
tobe1424
Feb 25, 2006 10:12 AM
jazz215
Apr 17, 2003 08:22 PM
maximedx
12
Jan 29, 2002 05:44 AM
