Are Teg and Civic brake boosters the same?
Old Jun 8, 2005 | 03:00 PM
underage's Avatar
Default Are Teg and Civic brake boosters the same?
my 91 std needs a new brake booster but i don't feel like putting a new one on now and when i switch brakes(soon). i was wondering, can i use the integra master cylinder (which i would get later) with a civic brake booster? or vice versa?
Old Jun 8, 2005 | 06:23 PM
underage's Avatar
bump, surely somebody did the teg brake swap that would know.
Old Jun 8, 2005 | 07:08 PM
konlao's Avatar
Default Re: (underage)
yes 90-92.....
Old Jun 8, 2005 | 07:13 PM
bagpipe goatee's Avatar
i was pretty sure the master cylinder attachment was rotated 90 degrees between the teg and civic...
just get the teg master cylinder and booster at the same time, make sure it's non-abs, because it's easier. also, you can't mix abs boosters and m/c's with non-abs ones.
Old Jun 8, 2005 | 07:19 PM
underage's Avatar
so, if i buy a civic brake booster the teg mc will work if rotated?
just making sure
Modified by underage at 11:55 PM 6/8/2005
Old Jun 8, 2005 | 08:16 PM
Tbindas's Avatar
urm... the g2 non abs integra components will not wokr... i have pictures if you have any questions... aim:boosted91da9
Old Jun 9, 2005 | 01:46 PM
underage's Avatar
so your saying that when i change to a 90-93 master cylinder, i will also have to change the booster?
Old Jun 9, 2005 | 01:51 PM
onePOINTsix's Avatar
yes, whoever said civic and teg boosters are the same is very wrong. A Teg booster is larger in size and the MC is mounted at a different angle. You need to use both MC and BC from a non-ABS DA
Old Jun 9, 2005 | 06:08 PM
underage's Avatar
thanks
Old Jun 9, 2005 | 06:33 PM
drdisco69's Avatar
To save some trouble with bending the lines around, just get the master cylinder from the EF Civic EX sedan. It's the same size and bolts up to the stock Civic booster and the lines plug right in. Swapping the booster as well to get the same thing as the Civic would get you seems like a waste of time.
PEK*EGGEM
Jul 24, 2009 05:41 PM
trustnoone7935
Apr 13, 2005 10:49 PM
RedDelSol si
Mar 10, 2004 07:54 AM
model x
19
Nov 3, 2002 10:19 PM
Eggman
Oct 7, 2002 09:18 AM
