99Si, Traction Bar Issues with my Si body?
i heard with a 99-00 SI, using L-Con Trac. Bars, i must switch my front lower LCA's with 92-95 civic LCA's, correct?
if anyone can add info or pictures, that would be Greatttt
theres another company that makes traction bars that bolt to the shock fork, so it would fit SI models also. I think it was Lakewood or something. but all non SI 96-00 civics have the 2 piece LCAs. The SI has the stamped steel ones. If you lose those LCAs you have to lose your sway bar also
you can have mounts made and welded to you arms. someone on here did that a while back and posted pics. this is the way i will go when i get the money. or you can get the standard civic arms and use the drop links a meber here makes. <not worth it imo because you have to buy too much stuff. i could find those threads and pics but i'm tiared and lazy right now.
start digging here https://honda-tech.com/zerosearch
Sprockets
Northeast (Sales)
Jul 11, 2010 10:46 PM
portfl0w
Aug 19, 2007 02:29 PM
