99Si, Traction Bar Issues with my Si body?
i heard with a 99-00 SI, using L-Con Trac. Bars, i must switch my front lower LCA's with 92-95 civic LCA's, correct?
if anyone can add info or pictures, that would be Greatttt |
theres another company that makes traction bars that bolt to the shock fork, so it would fit SI models also. I think it was Lakewood or something. but all non SI 96-00 civics have the 2 piece LCAs. The SI has the stamped steel ones. If you lose those LCAs you have to lose your sway bar also
Re: (a_kaibigan)
you can have mounts made and welded to you arms. someone on here did that a while back and posted pics. this is the way i will go when i get the money. or you can get the standard civic arms and use the drop links a meber here makes. <not worth it imo because you have to buy too much stuff. i could find those threads and pics but i'm tiared and lazy right now.
start digging here https://honda-tech.com/zerosearch https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (snail)
full race and z 10 make it where oem Si LCAs work i found out
