b-series header flange diagram
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by discrete »</TD></TR><TR><TD CLASS="quote">Phew, I finally sourced a head gasket.
Just to make sure, the b-series are all the same as far as exhaust ports go, right?
(not including the b20)</TD></TR></TABLE>
Yes, they're all the same. But out of curiosity, what need do you have for such minute accuracy in terms of the flange?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Yes, they're all the same. But out of curiosity, what need do you have for such minute accuracy in terms of the flange? </TD></TR></TABLE>
i'm not even sure the gasket you are going to trace is made with 0.001 accuracy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eag36 »</TD></TR><TR><TD CLASS="quote">i'm not even sure the gasket you are going to trace is made with 0.001 accuracy</TD></TR></TABLE>
It almost certainly isn't, and you'll find very small differences between the gasket ports, those of the head itself, and those found on stock and aftermarket exhaust manifolds.
That's basically what I was alluding to, the fact that such extreme accuracy really isn't necessary to construct a suitable header flange.
Da1spaz247
Welding / Fabrication
Apr 14, 2006 10:19 AM
chinoty
Aug 5, 2005 10:19 AM
