-- Civic VX model compared to other models, anything the same? --
I got a VX model 92-95 civic, and what would it be more compared to in terms of upgrading it? Let's say there is an item that says for CX/DX and there was no item for the VX, would it matter if I used whatever model and it would fit in my car? I know Si would definitely not fit.. Any help?
It kind of depends on what your buying. For instance if its an exhaust then you best bet would be to get a CX exhaust b/c they both have the cat on the exhaust manifold. The "Si def won't fit" theory is not necessarily true, just depends on what you're buying
There is no intake made to fit the VX throttle body. No aftermarket cat backs will fit without modification. All the suspension is still the same so you'll have no problems there. I have owned both a 92 and a 94 vx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">It kind of depends on what your buying. For instance if its an exhaust then you best bet would be to get a CX exhaust b/c they both have the cat on the exhaust manifold. The "Si def won't fit" theory is not necessarily true, just depends on what you're buying</TD></TR></TABLE>
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">There is no intake made to fit the VX throttle body. No aftermarket cat backs will fit without modification. All the suspension is still the same so you'll have no problems there. I have owned both a 92 and a 94 vx. </TD></TR></TABLE>
Cool that's what i'm also looking for! thanks!
Thanks!
dwnthehatch
Jan 14, 2003 07:27 AM
