coolant leak (overflow cap)
Old Jun 8, 2005 | 10:19 AM
jb_d81's Avatar
Default coolant leak (overflow cap)
My stock D16 seems to be leaking coolant around the overflow tank cap. I replaced the tank assuming that it was a problem with the tank not being able to hold pressure. the new one has the same problem. the engine temp seems to be stable until enough coolant boils and effectively leaks out of the overflow tank. after filling up the overflow tank and radiator it seems to be stable again. Anyone have any ideas?
Old Jun 8, 2005 | 10:23 AM
g2crx's Avatar
Default Re: coolant leak (jb_d81)
sounds like you might have a bad head gasket
Old Jun 8, 2005 | 10:25 AM
solareclipseauto's Avatar
Default Re: coolant leak (g2crx)
yeah check the head gasket, might have some minor cracks or could be blown
ZedEx's Avatar
****... Guess I have a bad head gasket then.
Old Jun 8, 2005 | 10:43 AM
jb_d81's Avatar
Default Re: coolant leak (solareclipseauto)
a blown head gasket would cause backpressure in the coolant system???
Old Jun 8, 2005 | 10:46 AM
ZedEx's Avatar
Not back pressure... Just extra pressure. Which is why I said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">****... Guess I have a bad head gasket then.</TD></TR></TABLE>
Because not only is my overflow tank boiling over... But my Water Pump is leaking again. All of these things point towards a bad Head Gasket.
Old Jun 9, 2005 | 01:24 PM
UK '94 Coupe's Avatar
Hi my d15b7 has the exact same problem so could you let me know what you found to be the fault, hoping it is just the head gasket!Thanx in advance
Old Jun 9, 2005 | 02:18 PM
northkai3's Avatar
Default Re: coolant leak (UK '94 Coupe)
i think ur problem is the radiator cap!! if the spring is broken the system doesnt pressurize because the coolant heats up and just continues to leak into the overflow and starts to boil out i had the same problem for 10 dollars at discount auto its worth a try! answer me this is ur radiator fan turning on?
Old Jun 13, 2005 | 02:38 PM
Yeah the fan comes on as normal and I know the system pressurizes. Flushed the system several times, water is pumping round and we have bled the system also. Its getting really frustrating so going to do the gasket and hope for the best cant think what else it could be unless i have cracked the head or block?!
DEPintheCurve
15
Sep 9, 2013 01:57 PM
mattj1988
Honda Civic (2001 - 2005)
Nov 30, 2012 03:08 PM
YAGGA_YA
Jun 15, 2011 12:04 PM
Hondapreludeg
Oct 3, 2008 06:20 PM
EKstacy
Dec 20, 2007 11:57 AM
