speedo reading 0 while driving...please help!!
Old Jun 8, 2005 | 07:01 AM
speed.freak's Avatar
Default speedo reading 0 while driving...please help!!
My 93 civic's speedo will not move while driving, has someone else had this problem..please help!!
Old Jun 8, 2005 | 07:07 AM
solareclipseauto's Avatar
Default Re: speedo reading 0 while driving...please help!! (speed.freak)
is there a check engine light...maybe the speed sensor is bad
Old Jun 8, 2005 | 07:10 AM
Default Re: speedo reading 0 while driving...please help!! (solareclipseauto)
no, the check engine light does not come on. sometimes the odometer meter wont move also when the speedo does not move.
Old Jun 8, 2005 | 07:46 AM
malubawla's Avatar
take out the cluster and rewind the gear in the back for the speedo......
Old Jun 8, 2005 | 11:27 AM
UserX826's Avatar
does vtec engage? i'm having the same problem but it's just my speed sensor.. but my odometer doesn't move at all sense the sensor is dead..
Old Jun 8, 2005 | 11:48 AM
t0ekn3e's Avatar
i had that problem and it was a fuse your gas needle doesnt work also right?
Old Jun 8, 2005 | 12:02 PM
94sohcVTEC's Avatar
Default Re: (t0ekn3e)
My bro replaced his cluster and had that problem. There was this needle/wire you have to make sure is plugged in snug behind it all for the speedometer to react. It took a long while to fix using long needle nose pliers and a "pervert's mirror" to work behind everything without having to unplug all the cabling. He was so happy to remedy this.
Old Jun 8, 2005 | 01:40 PM
Crasian's Avatar
my car is currentkly having the same problem, i replaced my VS sensor and it still doesnt work, the cluster i just took out of my parts car and it was working before this :S
ryrex02
Dec 7, 2010 05:53 PM
96honda_EK
Oct 19, 2009 05:50 PM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
Jodster
14
Nov 9, 2006 07:42 AM
mmurphy
Mar 24, 2006 10:07 AM
