Type R and decent SQ can this be done ? with no sound deadening ?
Old Jun 7, 2005 | 09:22 PM
Kavehman's Avatar
Default Type R and decent SQ can this be done ? with no sound deadening ?
The current stock speakers in my type R are pretty crap.
Id like to replace them with something that will give me all around good quality sound, but i don't want to add any sound deadening in the doors.
Is it possible to get good quality sound with no sound deadening ?
And can anyone reccomend some good speakers i should consider, was thinkin alpine type R's, i had a type R sub before and thought it was pretty good SQ wise.
Old Jun 8, 2005 | 11:43 AM
fcm's Avatar
fcm
Old Fart
Default Re: Type R and decent SQ can this be done ? with no sound deadening ? (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">The current stock speakers in my type R are pretty crap.
And can anyone reccomend some good speakers i should consider, was thinkin alpine type R's, i had a type R sub before and thought it was pretty good SQ wise.</TD></TR></TABLE> Although you will hear a big diff. with aftermarket speakers, [if you have an aftermarket HU] mounting the speakers to the stock plastic speaker mounts, and not using any dampening material will not get the most out of any aftermarket speaker, but replacing the plastic mounts with custom MDF ones an the use of a little, [1 sq ft at each speaker, speaker kits] will make a huge diff. I run an Alpine HU and 4 Eclipse 6.5" 2ways, http://www.eclipse-web.com on custom MDF mounts for the front and custom MDF and fiberglass cabinets for the rears, no subs or amps, in my 94 LS good clean sound and all the bass I need. 94
Old Jun 8, 2005 | 07:19 PM
Loccusst's Avatar
You loose alot of power if you do not reinforce your panels. There is a formula for how many millemeters of movement on any panel is equal to 25 watts of power loss....just can't remember it.
Old Jun 8, 2005 | 07:36 PM
wbw3434's Avatar
You can get decent sound but you have to remember that if you have crappy equipment you get crappy sound. So make sure you have a decent headunit and an amplifier that has low distortion. You also might want think about the kind of sound you want from your "system".
Old Jun 11, 2005 | 09:31 PM
zeth_an's Avatar
i listened to a boston z6 in a civic. Sounds v.nice just by itself! of course it was powered with a good amp(gt-28?), pioneer 9450 HU, and also a very deep pocket :D
kuztodianJeff
Nov 1, 2009 10:55 PM
96civicHATCH
Audio / Security / Video
Apr 2, 2006 08:39 PM
redex94
Sep 18, 2004 07:45 PM
cvclover
Jul 17, 2004 08:10 AM
LHC
Feb 27, 2004 08:30 AM
