is the 88 civic hatch interior harness the same as a 88 crx harness??
Old Jun 7, 2005 | 08:32 PM
93formula's Avatar
Default is the 88 civic hatch interior harness the same as a 88 crx harness??
came across a 88 crx dash and harness, would like to knwo if the harness were the same for the hatch/crx's?
even if there not, due to say length, will i be able to use it?
Old Jun 7, 2005 | 11:41 PM
Rywire's Avatar
Default Re: is the 88 civic hatch interior harness the same as a 88 crx harness?? (93formula)
climat controll diff, and the models are all diff too
Old Jun 7, 2005 | 11:45 PM
93formula's Avatar
Default Re: is the 88 civic hatch interior harness the same as a 88 crx harness?? (droppedcrxsi)
hmmm, will my hatch harness work with the crx dash? im assuming it will.
the dash is crx si and my car is a dx
Old Jun 7, 2005 | 11:53 PM
Rywire's Avatar
yes with a si eng harness too, but its a tuff job man!!
Old Jun 8, 2005 | 12:09 AM
93formula's Avatar
well i guess i should state what im doing here.
i currently drive the 88 dx hatch. the 88 is rusted out beyond repair. picked up a 90 cx hatch dirt cheap with a rust free chassis.
so im building up the d16 and planned on swapping everything from the 88 chassis to the 90 chassis. the reason i want to swap the interior is because the 90 interior is ugly (when compared to the black/grey interior of the 88).
came across a 88 crx si that was being parted out and just needed to know if it would work, this way there would be less down time.
another option would be to just buy a complete si interior harness locally.
Old Jun 8, 2005 | 01:17 AM
Kryogen's Avatar
Use the CRX dash, Now about the wiring you have 1 option only without converting the body harness.
that is:: Use the original harness from your DX dash and use the old style climate control.
This is what I did when I put a CRX dash in my 88 HB dx.
Old Jun 8, 2005 | 04:12 AM
d16efsedan's Avatar
Default Re: (Kryogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen &raquo;</TD></TR><TR><TD CLASS="quote">Use the CRX dash, Now about the wiring you have 1 option only without converting the body harness.
This is what I did when I put a CRX dash in my 88 HB dx.</TD></TR></TABLE>I also did the same thing
Old Jun 8, 2005 | 12:32 PM
93formula's Avatar
Default Re: (d16efhatch)
any pics guys?
Old Jun 8, 2005 | 12:55 PM
Kryogen's Avatar
heres mine, http://www.thezcr.com/gallery/...age/3
dont know if its exactly the pic your looking for .
Heres another picture.... http://www.thezcr.com/gallery/...age/3
The only thing I noticed with the swap was where the Center console met the Dash its a little cocked to one side...Ive since taken care of some of it...so its not noticable anymore.
OH and 1 more thing, You HAVE TO use the brackets on the little hump in the center of the car from the CRX as well, or the bottom dash mount and Ebrake surround will not bolt down. And you DO NOT want to ride without the Lower dash mount, one big bump and you will have a Large crack in it.
Old Jun 8, 2005 | 01:03 PM
93formula's Avatar
thanks for the pics, one last question, will the crx cluster fit in the hatch dash?
Old Jun 8, 2005 | 01:07 PM
Kryogen's Avatar
Yes,
You will have to use the Civics metal brackets though. But most people never remove them when taking out a cluster, its just 4 screws and a little unplugging and its out.
vegas hoe
39
Jan 7, 2019 01:53 PM
StayKrafty
Dec 15, 2010 01:10 PM
mattcivic
Jul 1, 2008 09:11 PM
shackler
Mar 15, 2007 10:02 AM
