HELP!!!! integra brake upgrade master cylinder problems...
Old Jun 7, 2005 | 08:15 PM
Tbindas's Avatar
Default HELP!!!! integra brake upgrade master cylinder problems...
so i have a 91 civic hatch back that i dropped in a 90 b18a1 and the integra's front and rear brakes, and suspension....
problem being is that the integra master cylinder is 45 degrees off.. and the vacuum chamber (i think thats what that black thing around it is called...) doesn't fit where the civic one did...
what should i do to fix the sloppy brakes...
i was thinking that a 91 civic si master cylinder (with the disk brakes) would be larger than the dx one... is this true?
also i kept the civic proportioning valve. Should i change it over do the integra proportioning valve or should i leave it?
thanks to anyone in advance
Old Jun 8, 2005 | 01:21 AM
Kryogen's Avatar
get the Teg proportioning valve,
Also did the Car you got the MC and brake booster...did it have ABS brakes??
If it did you cannot bolt in those. you would have to make sure you got the NON ABS models.
Old Jun 8, 2005 | 05:25 AM
Tbindas's Avatar
the teg was non abs. and how much of a difference would that make because i would still be pushing only a small portion of the brake fluid that the integra master cylinder displaces
Old Jun 8, 2005 | 05:42 AM
CRX Toad's Avatar
The "vacuum chamber" you are talking about is the booster. You cannot use a Integra MC on a Civic booster. You must switch to the Integra booster. As Kryogen was saying that make sure that the Integra booster IS NOT ABS, it must be a NON ABS BOOSTER. If you don't want to switch out the booster you can use a MC from a 90-91 4dr EX (it must be and EX) and this will bolt on to the current booster you have and it is bigger than your current MC.
Old Jun 8, 2005 | 08:19 PM
Tbindas's Avatar
ok, thank you...
btw i was unsure if the integra booster would fit... is it the same size as the civic one?
Old Jun 8, 2005 | 08:26 PM
shawn_crx's Avatar
Default Re: (BuTT_MuPPeT)
I'll fit but have to use both MC and BB.
And for the PP Valve, you be better with a 40/40 valve.
Teg PP Valve.
Old Jun 8, 2005 | 08:27 PM
onePOINTsix's Avatar
no it's bigger but it will still bolt right in doing this sat
Old Jun 8, 2005 | 08:30 PM
Tbindas's Avatar
awesome... thanks (it looked like it was going to be really close and i didnt want to take the time to do it w/ out knowing it will work
95civic_ls_vtec
Jun 16, 2010 02:13 PM
96pgtmtx
11
Oct 14, 2008 01:00 AM
SmoothCTR
Feb 25, 2008 11:18 AM
Cyrus4g63
Mar 10, 2006 08:35 AM
blac00si
Jun 23, 2005 06:56 PM
