Spark Plugs help ?
Old Jun 7, 2005 | 05:38 PM
ferby's Avatar
Default Spark Plugs help ?
Is it necessary to replace the spark plug when getting a much greater size spark plug wire, such as 9 or 10.3mm.
What are the benefits if I do so?
thank you ver much, all comments appreciated.
Old Jun 7, 2005 | 06:31 PM
civiccpedx's Avatar
Default Re: Spark Plugs help ? (ferby)
no if you replace the wires(which is not smart, i did it, there is no gain, and they usually fail like in my case)
just go with OEM, honda made a great ignition system, keep it
Old Jun 7, 2005 | 08:24 PM
msajr38's Avatar
i agree dont got much bigger then stock unless u upgrade the ignition and keep stock plugs unless u get turbo or nitrous
Old Jun 7, 2005 | 09:04 PM
ferby's Avatar
Default Re: (msajr38)
check this out tho...
http://cgi.ebay.com/ebaymotors...=WDVW
Old Jun 7, 2005 | 09:05 PM
ferby's Avatar
Default Re: Spark Plugs help ? (civiccpedx)
check this out man
Old Jun 8, 2005 | 07:53 AM
malubawla's Avatar
looks decent, plugs are good though
Old Jun 8, 2005 | 08:00 AM
snatch's Avatar
Default Re: Spark Plugs help ? (malubawla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferby &raquo;</TD></TR><TR><TD CLASS="quote">check this out man
http://cgi.ebay.com/ebaymotors...=WDVW</TD></TR></TABLE>
No. As stated before, Honda made a good ignition system. Don't mess it up using Ractive wires on there. If you need to replace the wires and plugs, NGK plugs and NGK wires will work great as they are OEM.
hondadc2
Aug 7, 2008 11:37 AM
Dartanian
May 13, 2006 05:26 AM
LOSERboy
13
Aug 13, 2004 10:56 AM
lakers6902
May 25, 2004 03:59 PM
prelude JDM
May 14, 2003 05:17 PM
