My friend needs some fast help with his b16 99ex
my friend has a 99 civic ex with an obd1 b16 swap. His a/c hoses, the ones that run from the compressor to the condensor, do not fit so he has no a/c. okay then, the lines he has, the 99ex lines only fit the condensor but wont fit the compressor, and the b16 lines will only fit the compressor and not the condensor. So what lines does he needs that will fit both his compressor and condensor?
its 100 degrees in alabama!
TIY
TIY
cool guy name
Re: My friend needs some fast help with his b16 99ex (Shift_Vtec)
I believe you need all of the civic ac stuff and get a DOHC delsol ac bracket.
Thats if I understand your question
if he had a/c in his car he can use his whole setup from the car except the bracket which is gonna hold the a/c and the pulley.......... i am running a 96+ del sol a/c bracket (pretty sure) part #: 38930-P54-000, but when you buy it it will most likely not come with a pulley so you need to get yourself a b-series pulley as well, bolt it on get the belt for the specific motor and your good to go........
lazyguy
06-09-2003 10:33 AM
