B16a idling probs(honda experts)
Old Feb 9, 2002 | 03:22 PM
Cory man's Avatar
Default B16a idling probs(honda experts)
B16a in an EF HB. The car runs and accelerates extremely well. But on occasion the car when brought to a stop will idle for a few seconds then slowly die. When I try to start it back up it wont. Then after a few mins I crank it up and its fine. Also when pumping the brake pedal at idle the idle increases and decreases by about 500 rpm(it goes up and down) I have tested the eacv and the fuel pressure reg. and map sensor and all are good. I have replaced the fuel pump and swapped in a coil. suggestions please
Old Feb 9, 2002 | 03:41 PM
tinkerbell's Avatar
Default Re: B16a idling probs(honda experts) (Cory man)
fast idle thermo valve?
Old Feb 9, 2002 | 03:56 PM
Kamin's Avatar
Default Re: B16a idling probs(honda experts) (tinkerbell)
check these 2 things
1) IACV (idle air control valve) take it off clean the screen
2) for your brakes, check the brake booster line that comes off the top of the intake manifold. i suspect you have a leak in it wich causes your idle to fluctuate when you press the brakes.
[Modified by KAMiN, 9:15 AM 2/10/2002]
Old Feb 9, 2002 | 04:00 PM
rainforest's Avatar
Default Re: B16a idling probs(honda experts) (KAMiN)
yep what they said are the problems that you need to check its something vacume wich is both of those right there.
cm8719500
Sep 11, 2009 12:27 AM
jdmvtecej2
Sep 24, 2008 05:20 PM
BlkB16aEJ
Aug 3, 2007 10:53 PM
ED9man
Jan 10, 2007 07:13 PM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
