Installing Rear Pads.. What the Hell is this Tab?
Old Jun 7, 2005 | 03:20 PM
Flux's Avatar
Default Installing Rear Pads.. What the Hell is this Tab?
Okay, it has been awhile since I've swapped out rear pads and even longer since I have seen stock rear pads. My new Cobalt GT-Sport rear pads came today, but I'm not sure what this big tab thing is on there... my other pads (Endless) had no such thing. What is this for? Can I just take it off?
Old Jun 7, 2005 | 03:21 PM
GSRrR's Avatar
Default Re: Installing Rear Pads.. What the Hell is this Tab? (Flux)
its there to let you know when to replace em....
Old Jun 7, 2005 | 03:22 PM
splitime's Avatar
Its a wear indicator... it'll squeak against the rotor when the pad gets low. If you monitor your pads well... which i'd assume you do if you have run pads without squealers before... just trim it off... otherwise its the inside pad on install.
machgo5go's Avatar
Its a WEAR indicator like the fronts.
Does it fit like OEM with this indicator?
It is good to have when it gets down so far in material that it will hit the rotor
making noise so you know you almost down to rivits.
Old Jun 7, 2005 | 04:11 PM
Flux's Avatar
Default Re: Installing Rear Pads.. What the Hell is this Tab? (machgo5go)
LOL - that makes sense... I feel like a noob. It had been so long since I had actually seen one of those damn things...
Old Jun 7, 2005 | 04:16 PM
migs's Avatar
n00b!
Old Jun 7, 2005 | 04:44 PM
Bbasso's Avatar
OMG!!!
Your so NOOBIE
Old Jun 7, 2005 | 07:38 PM
Ill's Avatar
Ill
Yep, using racer stuff all the time has it's disadvantages when you come back to the mortal world.
Totally applicable to car racing, and other forms of racing!
Old Jun 7, 2005 | 07:48 PM
JDMSpoonType-R's Avatar
Default Re: Installing Rear Pads.. What the Hell is this Tab? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">OMG!!!
Your so NOOBIE </TD></TR></TABLE>
Old Jun 8, 2005 | 03:30 PM
Renegade's Avatar
Default Re: Installing Rear Pads.. What the Hell is this Tab? (JDMSpoonType-R)
I thought it was so you can hang then from your rearview mirror when they are done.
Old Jun 8, 2005 | 03:47 PM
R you serious's Avatar
Default Re: Installing Rear Pads.. What the Hell is this Tab? (Renegade)
i take the tab off so i can flip my pads around.
da1lydr1ver
Sep 21, 2008 12:45 PM
an2ny888
Jan 29, 2007 07:12 AM
PatrickGSR94
Sep 14, 2005 05:02 PM
skunk2eg
Nov 3, 2004 11:58 AM
PatrickGSR94
May 25, 2004 10:18 AM
