pads squeeling, front or rear?
does the e-brake control the front brakes at all....my brakes are starting to squeel and if i pull the e-brake up slightly it goes away for a bit..
question is could it be my front pads at all or do i need to just replace the rear pads?
Re: pads squeeling, front or rear? (skunk2eg)
it could be your pads are low or your pads are stuck in the caliper.
if your pads are not low then remove the pads and clean them up and also clean the caliper and shims.
Re: pads squeeling, front or rear? (edd001)
they are fairly new, just replaced the front pads and rotors like 4 months ago..
does the anti-squell compound work well?
dont know. when we put new pads in we clean the shims and put a little copper grease on the back of the pads and the top and bottom of the pads where they sit in the calipers. it dose not take much for the pads to get stuck which is what i think your problem is.
Drums or disks? I'm assuming disk since you said rear pads.
The E-brake works the rear brakes, so if by using it the squeal goes away, that's probably where the problem lies.
Re: pads squeeling, front or rear? (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">Drums or disks? I'm assuming disk since you said rear pads.
yeah all wheel disc, i think its the rear brakes
MachAF
Suspension & Brakes
09-26-2009 10:02 AM
Toneman14
09-23-2005 08:29 AM
