Cams are rusted. what to do??
Old Jun 7, 2005 | 09:05 AM
baonest's Avatar
Default Cams are rusted. what to do??
i have a set of Jun3 cams that i stored away for a while. i opened them up today and well they have rust patches on them. when i put them away they had oil on them, so i am guessing the oil dryed up (i wrapped them in a towel, how dumb of me )
i was just curious what the best way is to get rid of this rust. rust convertor?
thanks
Old Jun 7, 2005 | 09:08 AM
Bbasso's Avatar
Default Re: Cams are rusted. what to do?? (baonest)
80 grit sand paper
Old Jun 7, 2005 | 09:13 AM
Eluder200K's Avatar
Default Re: Cams are rusted. what to do?? (Bbasso)
Old Jun 7, 2005 | 09:17 AM
Dave_B's Avatar
How bad is the rust? I'm assuming it's just superficial.
Old Jun 7, 2005 | 09:18 AM
JDM CTR '00's Avatar
Default Re: (01PY0559)
scotch brite
KayOs's Avatar
I like to use OxiSolve Rust remover to remove rust from auto parts.
It can be sourced here http://www.eastwoodco.com/shop...MOVER
After cleaning, apply some assembly lube to the camshafts.
Old Jun 7, 2005 | 09:35 AM
Gaylorde's Avatar
rust remover, if that doesn't work bring them to an engine machine shop for a polish.
Old Jun 7, 2005 | 09:38 AM
baonest's Avatar
Default Re: (Gaylorde)
cool. ill check out that rust remover stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">80 grit sand paper
</TD></TR></TABLE> then i could sell them as Jun1 cam shafts. lol
Old Jun 7, 2005 | 09:41 AM
jdmvtec28's Avatar
I had the same problem with some ITR cams I used to have... I ended up taking them to a machine shop and having the cams polished.
Old Jun 7, 2005 | 09:48 AM
white rocket's Avatar
You could sell them to me for real cheap
Old Jun 7, 2005 | 10:22 AM
Johnny Tran's Avatar
Default Re: Cams are rusted. what to do?? (Eluder200K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluder200K &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
personally, i like this guys thinking.
Old Jun 7, 2005 | 02:09 PM
Hooch'n's Avatar
Default Re: Cams are rusted. what to do?? (Johnny Tran)
thinking about pornQ!
Old Jun 7, 2005 | 04:30 PM
Mythias's Avatar
I would just use a very weak solution of oxalic acid. It will remove the rust and not harm the cams. Another option would be a gun cleaning solvent-- very effective at removing rust, and wont harm the metal at all.
Old Jun 7, 2005 | 04:35 PM
MinorityGreg's Avatar
Hondas are like Drugs (addictive)
Default Re: Cams are rusted. what to do?? (mythias)
get some swimming pool acid and mix it with some water. Like half and half.
Then spray it on, it will remove the rust. Then after that, just make sure to immediately lube the cams with wd40 or grease...
Old Jun 7, 2005 | 06:00 PM
baonest's Avatar
Default Re: Cams are rusted. what to do?? (MinorityGreg)
yeah, im pretty good at lubing
Old Jun 7, 2005 | 06:46 PM
Racermech's Avatar
If it is jsut surface rust why not try to rub it down with a clean rag and some WD-40 or "tri-flow" I have removed some basic surface rust with that method. If it is more than surface then i would follow the advice that others have posted
BIGef
Oct 11, 2013 02:07 AM
turbodelsolb16a2
12
Nov 30, 2010 12:17 PM
redDAinteg
Jan 6, 2008 11:57 AM
JDMflavor_EJ
Oct 31, 2004 11:48 PM
InfamousRS
May 12, 2002 03:02 PM
