swapping brake pads.
Old Jun 7, 2005 | 06:40 AM
freeway's Avatar
Default swapping brake pads.
Is there an easy way to push in the caliper piston when changing out the pads? i can get it pushed in enough to slide the new pads in. A little help? thanks guys.
Old Jun 7, 2005 | 06:48 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: swapping brake pads. (freeway)
I don't own an Integra, but I changed brake pads on various types of cars before.
With most pistons, I just use a large C-clamp to push it back in. Some pistons, like the rear disc on some Hondas, are turned instead of push, I use one of a specialized brake tool to turn it; but you can use a large screwdriver or pliers.
Old Jun 7, 2005 | 06:50 AM
jasonw's Avatar
For the rears, either get the right tool or use a sideways allen wrench.
There is also a tool you can get for the front that works better than a C-Clamp since the back of the piston is not really flat.
Old Jun 7, 2005 | 07:02 AM
freeway's Avatar
Thanks for the quick reply. Do you know if they turn or push in?
Old Jun 7, 2005 | 07:07 AM
jasonw's Avatar
Default Re: (freeway)
The fronts push in. The rears must be rotated.
Old Jun 7, 2005 | 08:55 AM
Sam92Teg's Avatar
Default Re: (jasonw)
To rotate the rear caliper piston in, I used an open end wrench placed in the groves, then stuck a screwdriver in the closed end of the wrench to turn it, worked like a charm.
andylawcc
Dec 22, 2009 04:00 PM
leviq
Jul 7, 2007 08:28 AM
LudeChild
Nov 16, 2004 05:27 PM
gsrclan
Nov 2, 2002 08:00 AM
J T*
Apr 23, 2002 04:27 PM
