b18 with 130 hp vs b18 with 140 hp
Old Jun 6, 2005 | 09:12 PM
chrisintegrab18's Avatar
Default b18 with 130 hp vs b18 with 140 hp
i have a 90 integra wit 130 hp what the hell give it 10 more hp is it the cams and if it is can i use the 96 to 00 cams from a ls.
Old Jun 6, 2005 | 10:39 PM
DAmn's Avatar
Default Re: b18 with 130 hp vs b18 with 140 hp (chrisintegrab18)
yes the cams are less agressive in the 90-91 as well as the intake manifold and exhaust mani. You can use cams from any 92-2000 ls motor but im not sure if there different enough to feel a diff. Hope this helps
Old Jun 7, 2005 | 04:30 AM
95lstegman's Avatar
Default Re: b18 with 130 hp vs b18 with 140 hp (DAmn)
much of the difference is in the cams. apart from that, the throttle body is 2mm smaller on the '90-'91 integras and the intake manifold is an even bigger joke than on the '92+ cars. that's it. by the time you're ready for a new intake manifold you'll have aftermarket cams and you'll need an aftermarket throttle body, so do some bolt-ons and then go aftermarket with these 3 parts unless you only have the budget for bolt-ons and want the extra hp. also, get a '92-'93 ECU. the fuel/ignition maps aren't the same and the redline is higher to make up for the higher peak power production.
hondathan
Jul 1, 2011 06:30 AM
stareatsun
Sep 20, 2004 05:29 AM
streetrage
Oct 16, 2003 10:02 AM
shaun23
Apr 16, 2003 06:35 PM
elmalouno
Jan 28, 2003 09:57 PM
