Built Turbo D16y8 or H22A4? What if you have $3000 to spend? Need opinions!!!
Old Jun 6, 2005 | 04:28 PM
BoostedCivic85's Avatar
Default Built Turbo D16y8 or H22A4? What if you have $3000 to spend? Need opinions!!!
Aight import fanatics! Need some expert opinions. I got about $3K to spend and I can't decide what route to take. For about a month now, I kept switching from one to the other. My goal is a reliable 350 WHP on a 97 Civic coupe. My current set up is a stock block D16y8, stock pistons, shotpeened rods, ported heads, 12 lb flywheel, Centerforce clutch, T3/T4 pieced by myself turbo kit with XS engineering FMIC, Type S BOV, FMU(piece of crap). Water/methanol injection. The car still runs but ready to be built again after 3 years of good abuse. Compression is going down, only 120 psi across. Just got Hondata S200.
Option 1 Sleeved D16 block .020 over $1200
SRP Pistons .020 over $425
Eagle rods $310
Stainless steel valves .5over $265
Valve springs $175
Titanium retainers $120
OBX intake manifold $175(Anyone got this?Good or Crap?)
Crower turbo cams $250
Misc stuff $500
TOTAL $3420
Option 2 H22A4 with built head Already got
Malhe pistons $380
Eagle rods $310
HCP Mounts $350(anyone got this?how is it?)
Hasport Axles $399(what axles can I use,90's integra?)
Accord Shift linkge Already got
Installation $600
H22 turbo manifold $250
Misc parts $500
Total $2840
Also, is there anyone running a stock block D16 with forged internals reaching 300 WHP? Your replies will greatly be appreciated. Thanks a lot.
Old Jun 6, 2005 | 04:33 PM
d15bcoupe's Avatar
Default Re: Built Turbo D16y8 or H22A4? What if you have $3000 to spend? Need opinions!!! (BoostedCivic85)
personally i think you'll be alot happier with the h.
Old Jun 6, 2005 | 04:34 PM
Quad-Damag's Avatar
sell the d series kit and go h22 u will love it
Old Jun 6, 2005 | 05:43 PM
.dave's Avatar
i HAS questions ?
Default Re: Built Turbo D16y8 or H22A4? What if you have $3000 to spend? Need opinions!!! (Quad-Damge)
H22 all the way.
Old Jun 6, 2005 | 05:46 PM
runnin9z's Avatar
Im not even sure if u can make 300 reliable hp with the D, personally id go the H22 route
Old Jun 6, 2005 | 05:48 PM
sohcvtec1995's Avatar
Default Re: Built Turbo D16y8 or H22A4? What if you have $3000 to spend? Need opinions!!! (1 cam)
Keep the d. Just dnt get the obx mani. stay stock or get a edelbrok or skunk2.
Old Jun 6, 2005 | 05:49 PM
Default Re: (runnin9z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runnin9z &raquo;</TD></TR><TR><TD CLASS="quote">Im not even sure if u can make 300 reliable hp with the D, personally id go the H22 route</TD></TR></TABLE>
yes you can.
Old Jun 6, 2005 | 06:54 PM
y7turbo's Avatar
Default Re: (sohcvtec1995)
keep the d man.. with 3 g you can build the motor like you want you can easy have over 300whp with a custom turbo kit..
just read and pick the right parts the first time..
Old Jun 6, 2005 | 06:58 PM
I second to that, yes yes you can get 300whp with the D with proper tuning. I'm not sure what's the limit with the stock block. Know couple D's running over 300whp and close to 400's but that's with sleeves. Anyone know? I know stock B series can handle well over 350whp. Honda blocks are strong. But without proper tuning, even a fully built even will go.
Thnx for the replies, hope to get some more. A D series with 350+whp will blow a V8's ego and a Turbo H22 in a EK Civic is tight. It's a matter of being humble with the D or show off the H.
Old Jun 6, 2005 | 08:18 PM
Morning Call's Avatar
theres more involved with the H then ur mentioning
u need axles/tranny/etc... itll cost more then 3k..
a turbo'd d would own a h
Old Jun 6, 2005 | 08:23 PM
EK k kay's Avatar
Default Re: (Morning Call)
I like the turbo d setup. Did you consider an ls turbo setup?
Old Jun 6, 2005 | 08:47 PM
BigMoneyP's Avatar
Default Re: (chowmien)
built y8 turbo. 300whp easy with custom turbo kit, look on turbod16, there is someone with pistons and rods at about 260whp.
Old Jun 6, 2005 | 08:54 PM
I did mention the axles in my setup. $399 from Hasport. I'm also aware of the headache that it involves doing the H22 that was why I included $600 for installation(a friend will install it for $600)I want to install it myself but I don't know what all that needed to be done..Also, both options are going to be turbocharged.
Yes, I did consider an LS turbo, I was in a junk yard today looking at some B18B's but decided not to. I still need to decide what to do with the H22 that's sitting in my garage. Put it in or sell it?
Old Jun 6, 2005 | 09:02 PM
EK k kay's Avatar
Default Re: (BoostedCivic85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivic85 &raquo;</TD></TR><TR><TD CLASS="quote">I did mention the axles in my setup. $399 from Hasport. I'm also aware of the headache that it involves doing the H22 that was why I included $600 for installation(a friend will install it for $600)I want to install it myself but I don't know what all that needed to be done..Also, both options are going to be turbocharged.
Yes, I did consider an LS turbo, I was in a junk yard today looking at some B18B's but decided not to. I still need to decide what to do with the H22 that's sitting in my garage. Put it in or sell it? </TD></TR></TABLE>
You got a lot of options. I'd be confused as to what I'd want to do as you are.
Old Jun 6, 2005 | 09:05 PM
EJAYATE's Avatar
I Deliver
Turbo y8, cause its what I want to do. I got 2g saved up hoping to get another g soon so I can slap on an sc-61, until the d explodes then I'll swap to a b. The h will be a headache, but if you got the money, there is more potential in an H IMO.
Old Jun 6, 2005 | 09:16 PM
Default Re: (B2CivMan)
D series is winning so far, it was H in the beginning. I guess D it is. Now I can sleep better. I just hate smoking in the garage looking at that freakin' huge valve cover that says DOHC VTEC. I have to put a blanket over it I guess, it keeps brainwashing me everytime I see it, did I mention the Greddy 18g that's mounted to it. Crap, here I go again. Thanks for the replies. I can accept more. Any one for H22's?
Old Jun 6, 2005 | 09:19 PM
willyboyK20's Avatar
i would keep the d since u already got it. Work with what u got.
For the H22 don't u have to resleeve to add forged pistons.
Old Jun 6, 2005 | 09:27 PM
APEXI Si's Avatar
Default Re: Built Turbo D16y8 or H22A4? What if you have $3000 to spend? Need opinions!!! (willyboyD16)
Go boost.
I have 201 whp and 175 wtq on a stock D. 1500 bux invested.
Old Jun 6, 2005 | 09:33 PM
Mahle pistons made pistons designed for H22 so you don't have to sleeve it. It has a goldish color coating on the side of the pistons. One of the reason why I wanted to keep the H22, but more work.
What will you choose? Sleeved D16 or Stock H22 with block guard?
Jeff<3'sHonda
Jul 15, 2014 08:44 PM
97ek4
Sep 26, 2009 06:07 PM
txsynergy
Jan 12, 2005 08:15 AM
