AXLE REMOVAL PROBLEM
Old Jun 6, 2005 | 03:40 PM
law_teg_92_R's Avatar
Default AXLE REMOVAL PROBLEM
Alright, so today i was getting ready to take my axle out. i didnt feel like taking my ball-joints apart and so i took it all apart so the whole thing swung up. and the axle that is on the drivers side, the female end of the axle wont come apart from the male end of the male end of the intermedete shaft. i tried to hit it and stuff and it will not diconnect. i dont have much room so anything that would help thanks
Old Jun 6, 2005 | 03:45 PM
HGZ's Avatar
HGZ
Default Re: AXLE REMOVAL PROBLEM (law_teg_92_R)
why not just remove the intermediate shaft along with the axle, then disconnect them while they're off the car?
Old Jun 6, 2005 | 03:46 PM
gsrboi80's Avatar
did u get the side out of the hub If so use a pry bar or a thick screwdriver and pluck that bitch out. Works for me
Old Jun 6, 2005 | 04:04 PM
matto23's Avatar
i had this same problem on my h22civic, and i searched HT and found this ******* cool trick. you use various sized deep sockets as a "wedge" between the inner joint and the inner shaft and beat the hell out of it with a hammer. when i first tried this, it didn't work. so i had to remove the inner shaft (entire assembly), and proceed with the same process except with the axle and shaft on the ground. once off the car, the process takes about 5 seconds.
cliff notes: un-bolt the inner shaft. put it on the ground. wedge a 21mm deep socket between the inner joint and inner shaft. and beat the **** out it with the hammer. if need be, use a larger socket
Old Jun 8, 2005 | 12:12 PM
ok so today after school i went and took out the whole thing and we still cant get it to come apart so i was wondering if anyone can explain the trick wiht the 21mm socket a little more, thanks
Old Jun 8, 2005 | 12:24 PM
E_Racer's Avatar
yea that shiet is B**tch. i had to take out the whole axel when replacing my alternator. goodluck cuz i busted my *** trying to take it apart for 4 days and i ended up having to replace the whole axel cuz i got it spread apart about 1/4 inch. then i tried to put it back toghter, it wouldnt go back in.
Old Jun 8, 2005 | 02:53 PM
solareclipseauto's Avatar
Default Re: AXLE REMOVAL PROBLEM (E_Racer)
unbolt the intermediate chaft and pull the whole thing out
Old Jun 8, 2005 | 04:27 PM
matto23's Avatar
here ya go, i pmed you back. here is the pick
Old Jun 8, 2005 | 05:16 PM
gsrious's Avatar
you should just use an adjustable wrench and open it to the point where the wrench fits snuggly in between the intermediate shaft and axle... withe the handle part of the wrench--> hit it with a hamer and it'll pop right off.
this way of doing it doesn't require you to take off the intermediate shaft and takes about 2 min.
Cap'N Chronic
Jun 29, 2011 12:54 PM
EGPrelude
Jun 17, 2008 07:46 AM
B18CYAAA
Aug 11, 2007 04:38 PM
Hoppa
Dec 5, 2006 08:51 AM
huepowered
Mar 27, 2006 12:33 PM
