My VTECH doesn't work :(
Old Jun 6, 2005 | 11:57 AM
thewonderer's Avatar
Default VTEC WONT KICK!? HELP ME FIND OUT WHY
I wired my ek shell (CX) for vtec. Now it wont work/kick/pop in. I have to run the o2 sensor still because they are still short and i have to run the speed sensor. Will any of these two sensors disable my vtec from popping? let me know
ps im running the harness to a harness jumper over to obd1 p28 chipped. When i run the GSR P72 that came with the motor, when vtec is supposed to kick the engine makes like its rev limiting and wont let the rpms go past were the vtec is supposed to pop. Thats why im using the chipped p28
Old Jun 6, 2005 | 12:11 PM
2lua's Avatar
Default Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (thewonderer)
off the top of my head. before the vtec to activate there are few things that it required. oil pressure, speed...
Old Jun 6, 2005 | 12:21 PM
screech's Avatar
i dont think the o2 will affect it but the speed sensor (you have to be going 15mph for vtec to engage i think or something like that) and reason its hittin "rev limit" is you should be throwin a vtec system malfunction CEL which shuts your car down right at vtec engagement point
Old Jun 6, 2005 | 12:46 PM
IHateJDM's Avatar
Default Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (screech)
I wouldn't run the car without the o2 if I were you, and yes the speed sensor needs to be hooked up for vtec.
Old Jun 6, 2005 | 01:30 PM
Brodie Bruce's Avatar
speed sensor is needed
Old Jun 6, 2005 | 01:32 PM
Kamin's Avatar
Default Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (xavenged7x)
http://info.honda-tech.com/ind...oting
speed sensor is 100% necessary for vtec.
Old Jun 6, 2005 | 01:36 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screech &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the o2 will affect it but the speed sensor (you have to be going 15mph for vtec to engage i think or something like that) and reason its hittin "rev limit" is you should be throwin a vtec system malfunction CEL which shuts your car down right at vtec engagement point</TD></TR></TABLE>
I believe its 20mph and the car has to be at running temperature before it will kick in.
BTW, are you running a P28 or an ECU w/ VTEC? (I don't know if the CX motors came w/ VTEC or not)
Old Jun 6, 2005 | 07:46 PM
UserX826's Avatar
it's the vss.. same problem here.. anybody wanna sell me an obd2 vss?
Old Jun 7, 2005 | 04:12 AM
Hurricane's Avatar
Default Re: (UserX826)
VSS, causing it to be in limp mode, NO VTEC when limping.
Old Jun 7, 2005 | 08:03 AM
Kamin's Avatar
Default Re: (Hurricane)
no speed sensor dosent cause limp mode.
Old Jun 7, 2005 | 01:54 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Kamin)
VTEC doesnt work if you're throwing any CEL's.
Old Jun 7, 2005 | 02:04 PM
familyhauler's Avatar
Default Re: (jlacoy82)
I believe jla is right on this one from what i know i dont think Vtec will work with any check engines on, and even so yes the car has to be warmed up before Vtec will kick on.
Old Jun 7, 2005 | 02:05 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">VTEC doesnt work if you're throwing any CEL's.</TD></TR></TABLE>
bullshit
only certain CEL's will eliminate vtec.
VSS is one. but the VSS wont put it into limp mode
if you dont belive me unplug your o2 sensors and go for a drive. vtec will work and your CEL will be on.
Old Jun 7, 2005 | 02:07 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
bullshit
if you dont belive me unplug your o2 sensors and go for a drive. vtec will work and your CEL will be on. </TD></TR></TABLE>
WHERE IS MY O2 SENSUR?!?
Old Jun 7, 2005 | 02:21 PM
Kamin's Avatar
if you dont know where your o2 sensor(s) are you shouldnt be selling a fully built head in your signature
Old Jun 7, 2005 | 07:27 PM
b18c5 EG's Avatar
o damn i thought this was about your VTECH phone...guess i cant help
Old Jun 7, 2005 | 08:06 PM
Jay-Spec02's Avatar
that sucks...
Old Jun 7, 2005 | 08:28 PM
Crasian's Avatar
Default Re: (94_Del Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_Del Sol &raquo;</TD></TR><TR><TD CLASS="quote">o damn i thought this was about your VTECH phone...guess i cant help</TD></TR></TABLE>LOL, same here, i was gonna refer him to radio shack, they have a wide assortment of vtech phones so they could probabky fix it
Old Jun 7, 2005 | 08:55 PM
B16aDasher's Avatar
Default Re: (FarOutCoupe)
did you convert the o2 sensor?
Old Jun 7, 2005 | 09:07 PM
BS 22's Avatar
hmmm when I saw this thread eariler today, it didn't say VTECH...
Old Jun 7, 2005 | 09:12 PM
al3e's Avatar
Default Re: (Kamin)
lol when i slapped my vtec swap in my cx.. i still hit vtec with out wires from my ecu... and it was an 93... not 92... and no there were no wires... yeah weird,...?
well i donno bout ur prob man sorry good luck
Old Jun 7, 2005 | 10:57 PM
Combustion Contraption's Avatar
Default Re: (al3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e &raquo;</TD></TR><TR><TD CLASS="quote">lol when i slapped my vtec swap in my cx.. i still hit vtec with out wires from my ecu... and it was an 93... not 92... and no there were no wires... yeah weird,...?
well i donno bout ur prob man sorry good luck </TD></TR></TABLE>
Nope.
Old Jun 8, 2005 | 01:26 AM
siregcivic's Avatar
Default Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (BS 22)
if you have any check engine light your vtec wont work..... the only difference between obd1 and obd2 is that obd1 with a check engine light you can still take it to redline....
obd2 you will have a governer around 5 grand to 5,500
Old Jun 8, 2005 | 05:06 AM
IHateJDM's Avatar
Default Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">if you have any check engine light your vtec wont work..... the only difference between obd1 and obd2 is that obd1 with a check engine light you can still take it to redline....
obd2 you will have a governer around 5 grand to 5,500</TD></TR></TABLE>
nope. as said before vtec can work with a cel. I know this for a fact because i've done it. The 5 grand governor is probably limp mode. limp mode only occurs with certain cels. 90% of the people who come on here claiming they are in limp mode really have no idea what limp mode is.
Old Jun 8, 2005 | 05:50 AM
senpai's Avatar
Default Re: VTEC WONT KICK!? HELP ME FIND OUT WHY (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
nope. as said before vtec can work with a cel. I know this for a fact because i've done it. The 5 grand governor is probably limp mode. limp mode only occurs with certain cels. 90% of the people who come on here claiming they are in limp mode really have no idea what limp mode is.</TD></TR></TABLE>
correct - some ppl are just e-mechanics
