will the d16y8 header fit the y7???
Old Jun 6, 2005 | 09:26 AM
Project_EK's Avatar
Default will the d16y8 header fit the y7???
hello,
i found a clean d16y8 header for cheap..will it fit my d16y7 (non vtec) motor?
thanks
Old Jun 6, 2005 | 09:45 AM
Project_EK's Avatar
Old Jun 6, 2005 | 09:46 AM
TheNasty0ne's Avatar
Default Re: will the d16y8 header fit the y7??? (EKhatch219)
Yes it will but you'll need to cover up the o2 sensor i believe
Old Jun 6, 2005 | 09:51 AM
WildPig's Avatar
Default Re: will the d16y8 header fit the y7??? (OoBryan)
Yes it will, although you will need to get an ex or si cat and you will also need to lengthen your secondary o2 sensor harness.
The y7 cat is actually in the header so that's why you need a ex style cat.
And also the ones on ebay are not cats, they're testpipes so try and find a used one.
Old Jun 6, 2005 | 09:54 AM
sohcvtec1995's Avatar
Default Re: will the d16y8 header fit the y7??? (WildPig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will, although you will need to get an ex or si cat and you will also need to lengthen your secondary o2 sensor harness.
And also the ones on ebay are not cats, they're testpipes so try and find a used one.</TD></TR></TABLE>
exactly. also when you go to get a catback(assuming you dnt have one already.) it will have to be for a ex.
Old Jun 6, 2005 | 10:09 AM
WildPig's Avatar
Default Re: will the d16y8 header fit the y7??? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
exactly. also when you go to get a catback(assuming you dnt have one already.) it will have to be for a ex.</TD></TR></TABLE>
Are you sure? I keep hearing about this but I would think that the ex coupe exhaust would have to be longer than the dx hatch and on the hatch it would stick out too much........
I have a dx hatch and I had an apexi n1 before I did the header and I just took my car to a muffler shop and they just cut the middle pipe of my exhaust to make it fit and bolt up.
^^^^ forgot to mention that in my earlier post. Whoops.
Old Jun 6, 2005 | 10:14 AM
Well the reason why i stated this is just so that its easier to install. As in your case they had to modify your exhuast to work with the rest. But if you go all ex then you would be fine. In the case of the hatches, It would have to be modified no matter what. Unless you got everything from a Y7, i.e. header, and exhuast.
Old Jun 6, 2005 | 10:27 AM
WildPig's Avatar
Gotcha........ so it is how I thought, if you have a dx hatch then you can't get an ex exhaust to make it easier, you have to modify your dx exhaust.
Old Jun 6, 2005 | 10:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">Gotcha........ so it is how I thought, if you have a dx hatch then you can't get an ex exhaust to make it easier, you have to modify your dx exhaust.</TD></TR></TABLE>
this is onbly the case with the Hatch not the coupe. Since the hatch dose not have the vtec motor. But with coupes you just get all ex stuff.
Old Jun 6, 2005 | 11:47 AM
716pro's Avatar
buy mine they might work https://honda-tech.com/zerothread?id=1267752
does any one know if these header will fit anything else?
Old Jun 6, 2005 | 12:18 PM
Project_EK's Avatar
how do i extend the sencond o2?
Old Jun 6, 2005 | 01:03 PM
Dr. D-Series's Avatar
Placing the Y8 header on the y7 head will delete the cat and bolt up to your cat back piping.
If you must add a cat, by a ex exhaust catback, or shorter your current one and add a cat.
Old Jun 6, 2005 | 01:07 PM
WildPig's Avatar
Default Re: (EKhatch219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch219 &raquo;</TD></TR><TR><TD CLASS="quote">how do i extend the sencond o2?</TD></TR></TABLE>
Get some wire from napa or somewhere and cut your o2 sensor harness wires before the plug and splice and solder in the new wires and that extends it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 716pro &raquo;</TD></TR><TR><TD CLASS="quote">buy mine they might work https://honda-tech.com/zerothread?id=1267752
He said he already had a header......... and they will fit other d series engines.
Old Jun 6, 2005 | 01:10 PM
WildPig's Avatar
Default Re: (Dr. D-Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">Placing the Y8 header on the y7 head will delete the cat and bolt up to your cat back piping.
If you must add a cat, by a ex exhaust catback, or shorter your current one and add a cat.</TD></TR></TABLE>
It will delete the cat, but throw a code, make you run rich and also pollute and smell like ****. Trust me, get an ex cat and do it right.
Old Jun 6, 2005 | 01:19 PM
EK k kay's Avatar
Default Re: (WildPig)
It will delete the cat, but throw a code, make you run rich and also pollute and smell like ****. Trust me, get an ex cat and do it right.</TD></TR></TABLE>
I heard the secondary o2 doesn't do anything rather than monitor the exhaust after it goes through the cat. Even though it throws a cel it does not modify the ecu settings.
I am in the process of doing this modification on my y7/y8 mini me setup. I have an oem y8 exhaust manifold and oem si cat on their way and when I get them I will go to a muffler shop and have them cut my stock b-pipe and weld a new 3-bolt flange on it so I can utilize the standard cat. Then I'm going to extend my o2 sensor wires.
Old Jun 7, 2005 | 01:07 PM
Project_EK's Avatar
so the y8 header without the cat will
attach right up to my oem exhaust?
Old Jun 7, 2005 | 04:34 PM
Ghetto Civic HX's Avatar
I love to drive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch219 &raquo;</TD></TR><TR><TD CLASS="quote">so the y8 header without the cat will
attach right up to my oem exhaust?</TD></TR></TABLE>
Only if you had a 2/4 door. But the hatches exhaust is different. Especially your's which has already been modified.
Old Jun 8, 2005 | 04:52 AM
Project_EK's Avatar
thanks
thead
Oct 25, 2010 02:52 PM
jdm integ
Feb 23, 2006 06:00 PM
UnitZero
13
Feb 24, 2005 07:06 PM
SleepnCiViC
12
Dec 12, 2003 04:01 PM
mhgleitz
Sep 21, 2003 06:29 PM
