Which one??
im alittle confused on a swap or build to do..i have some ideas just cant really make up my mind and if someone has done anything close let me know some #'s
b16 12.?? compression pistons, and simple mods to the head like p&p, 3angle valve job etc. etc. , and a b16 tranny with LSD, and alittle bit of nitrous
OR
LS turbo p&P head, b16 pistons, b16 tranny,
OOOOORRRRR
D15b turbo, fully built head
my budget is about $5000 for a build...
OR
OOOOORRRRR
the b16a is a great platform to build on. they're still readily available, and so are parts. boost, na, or juiced, any way you go will work. imo, you can squeeze a high comp honda motor, but tuning is of the essence. with that kind of compression, id either sleeve the block or use an alternative protection device. good luck!
