just bought a b18b bare block...what internals to put in it???
i jsut bouhgt a b18b block bare. its just the block and oil pan no crank rods or pistons. im plannin to put it with a b16 head...i was wondering what kinda internals should i put with it? my goal is a budget streetable motor on 91 octane hopin to hit 200whp
So you want to run LS/Vtec correct?
For a budget good bottom end do the following.
-LS crank
-LS rods
-APR Rod bolts
-p30 pistons
-ACL race bearings or just oem factory rod/crank bearings
-GSR head bolts
-b16 head and do valvetrain upgrade...with nice set of camshafts and cam gears
That should be some good basic info to help you start on the build
-LS crank
-LS rods
-APR Rod bolts
-p30 pistons
-GSR head bolts
eg4life1202
Jan 11, 2007 04:54 AM
