Rough Idle and check engine light???
Old Jun 5, 2005 | 03:59 PM
darylfiend11's Avatar
Default Rough Idle and check engine light???
First off I have a 92 SI H23, Just got the motor rebuilt now im having troubles at idle it surges from abot 2grand down to 100 and dies when I come to stops. There are no cel's until I drive and hit about 4th gear and the it throws a code 23 Knock Sensor. Are the two related to each other, im not sure where to go from here. Any help would be great.
Old Jun 5, 2005 | 04:36 PM
Mikey3000's Avatar
Default Re: Rough Idle and check engine light??? (darylfiend11)
the knock sensor wouldnt give you idle problems. it could be a vacuum leak. did you do anything to your throttle body or get a new intake manifold or anything like that when you rebuilt your motor? oh, it could also be air in your coolant system. try bleeding coolant at the thermostat housing until you see a flow of coolant only (no air bubbles).
st00lenpeace
Jan 16, 2011 03:46 PM
VTECchris
Nov 7, 2008 11:20 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
fast4w$
Jan 9, 2004 10:04 AM
volkracing99
Jan 24, 2003 07:45 PM
