igniter gone south?
My problem is that the car dies after a few seconds of running. And it would start right up every crank, just wouldn't stay running.
Will replace the distributor next week.
Stock 91 si
Stock 91 si
Pull a plug wire put a spark pug in it, then put the spark plug next to ground if it sparks look else were. No spark more than likely your probelm. Was is warm to hot when it happened? Mine went bad this week adn it was about 85 degrees out. They Normal go bad in the heat.
StreetRiot_DRE
25
Dec 10, 2007 07:19 PM
4DRmafia
11
Nov 23, 2005 11:04 AM
