:rear rotor piston question:
Old Jun 5, 2005 | 11:45 AM
spock_rocker's Avatar
memoryFAB.com representative
Default :rear caliper piston question:
*i meant caliper* man im not with it today!!
i removed the old pads from the used rear discs i bought and i was wondering if i need to rotate the piston before putting the new pads in?? thank you
Old Jun 5, 2005 | 12:12 PM
pdiggitydogg's Avatar
The slot on the piston needs to line up with the tab on the pad.
You can see and mess with it through the hole on the backside
Old Jun 5, 2005 | 12:31 PM
Default Re: (pdiggitydogg)
the piston is extended from the body, and needs to be compressed??
Old Jun 5, 2005 | 12:39 PM
Right.
Spin it so it will fit over the fatter pads, then spin it a bit again, to line it up
Old Jun 5, 2005 | 02:17 PM
mrchaos's Avatar
Default Re: :rear caliper piston question: (spock_rocker)
get a pair of needle nose pilers, open them wide enough to fit in the grooves....turn, turn, turn until the piston goes back in
Old Jun 6, 2005 | 05:48 AM
Default Re: :rear caliper piston question: (mrchaos)
ok thank you.. thats kinda what i figured! i appreciate it guys!
slushyhut
Honda CR-V & Element
Feb 18, 2024 06:40 PM
Beetlejuice
Mar 31, 2004 10:30 AM
Louie_EM1
Mar 14, 2004 09:40 PM
SKDRCR
Jan 18, 2004 05:18 PM
D
Aug 6, 2001 06:21 AM
