testing fuel pump pressure 95 accord
anyone know where to get the attachment or attachments that allow you to test the fuel pump pressure in a 95 accord. i see the test port on the fuel rail but i've never seen a quick disconnect fitting that large. and the stuff i have has nothing that willl fit that small a thread hole.
found it quite by accident. a neighbor was asking me about checking his air conditioner and wouldn't you know the high side fitting is an exact match to the fuel rail test port. i hooked it up and it read 35psi. so there is no fuel pump leak. also be careful not to loose the washer under the jam nut on the test port. it's a special washer and nothing in your tool box will work.
