if i have a high flow catalytic converter....
Old Jun 5, 2005 | 06:58 AM
sfgiants11's Avatar
Default if i have a high flow catalytic converter....
will that cause my check engine light to throw codes?
Old Jun 5, 2005 | 07:01 AM
Sly_Samba's Avatar
HTBATRACER
Default Re: if i have a high flow catalytic converter.... (sfgiants11)
no...unless you previously had an o2 which went into the cat and you didnt put it back on...
Old Jun 5, 2005 | 07:16 AM
sfgiants11's Avatar
Default Re: if i have a high flow catalytic converter.... (tihul)
when i swapped the CAT i swapped the stock o2 sensor with just a bosch brand name o2 sensor, but according to the diagnostic check, it doesn't like something to do with my exhuast system
Old Jun 5, 2005 | 07:22 AM
dohcdelsol's Avatar
so you put on a new high flow cat with an aftermarket o2 sensor correct? And now your throwing a cel regarding your exhaust system. I think you answered your own question. Try puting the oem o2 sensor on and see if it goes away. Try putting the stock cat on with the bosch o2 sensor. If you get a cel, its the o2 sensor, if you dont, its your cat (which i doubt).
pumpkyn
Jan 30, 2006 11:59 PM
joshcivic00
Nov 11, 2005 10:49 PM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
smooz EK
12
Nov 12, 2003 10:07 AM
degradated
Nov 5, 2001 02:57 AM
