how to ID a ITR rear sway bar?
Old Jun 4, 2005 | 10:46 PM
BLUE EH3's Avatar
Help we my pennies
Default how to ID a ITR rear sway bar?
long story short, my boy looked under my EK and told i had a ITR sway bar. i thought he was just joking, till he showed me his GSR sway bar( boy it so small).
when i found that he mite be rite,i was happy and scared, HAPPY because i dont have to buy a SSR sway bar, SCARED becuase my subframe mite be tearing out.
-how do i know if i have JDM or USDM ITR sway bar?
- should i guess i NEED a A-spec subframe brace.. any other options?
Old Jun 5, 2005 | 07:37 AM
Bbasso's Avatar
Default Re: how to ID a ITR rear sway bar? (BLUE EH3)
is there a yellow or green paint mark on it?
Old Jun 5, 2005 | 07:44 AM
Opie's Avatar
Technically Rob, the ITR sway bar has either a champ white or yellow dot on them. Depending on what color R they are from. The ones with NBP/FBP dots are most definately NOT ITR sway bars.
Modified by Opie at 11:59 AM 6/5/2005
Old Jun 5, 2005 | 07:56 AM
Bbasso's Avatar
Default Re: (Opie)
And a yellow paint mark is from a JDM R... indicating 23mm.
Old Jun 5, 2005 | 07:57 AM
Opie's Avatar
The ones with Takata green dots are from California California show cars.
Old Jun 5, 2005 | 08:00 AM
Bbasso's Avatar
Default Re: (Bbasso)
https://honda-tech.com/zerothread?id=100159
Old Jun 5, 2005 | 08:29 AM
BLUE EH3's Avatar
Help we my pennies
my is all black
Old Jun 5, 2005 | 08:30 AM
BLUE EH3's Avatar
Help we my pennies
any other marking? size is the jdm bar vs the us itr bar?
Old Jun 5, 2005 | 08:31 AM
Chris93Si's Avatar
USDM = 22mm
JDM = 23mm
Old Jun 5, 2005 | 08:36 AM
BLUE EH3's Avatar
Help we my pennies
7cm="X"mm
Modified by BLUE EH3 at 12:55 PM 6/5/2005
Old Jun 5, 2005 | 09:06 AM
BLUE EH3's Avatar
Help we my pennies
i got my my mother pocket CM tape measure and it came to 7cm.......i cant have a 70mm bar
Old Jun 5, 2005 | 09:13 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">i got my my mother pocket CM tape measure and it came to 7cm.......i cant have a 70mm bar</TD></TR></TABLE>
You are measuring the diameter of the bar right?
Old Jun 5, 2005 | 09:18 AM
Chris F's Avatar
Diameter is what you should be measuring. You measured circumferance. You might need a caliper to get it accurately.
Fortunately, the Egyptians figured out trigonometry/geometry for us, and Archimedes calculated Pi to a few significant digits.
circumference = 2pi*r
70mm / 3.14159 = 2r, and 2r is diameter. Your bar is approximately 22.28 mm. I would guess between paint and corrosion it's 22mm. But only you know how accurately it was measured.
BLUE EH3's Avatar
Help we my pennies
Default Re: how to ID a ITR rear sway bar? (FunctionMotoring)
yes, around the bar!
Old Jun 5, 2005 | 09:19 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">yes, around the bar!</TD></TR></TABLE>
Diameter is thickness.. not circumference.. check Chris's post above
..sounds like you have a USDM R bar.
Old Jun 5, 2005 | 09:20 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: how to ID a ITR rear sway bar? (Chris F)
jdm=23
usdm=21
Old Jun 5, 2005 | 09:21 AM
BLUE EH3's Avatar
Help we my pennies
so how can i accurately measure it??
Old Jun 5, 2005 | 09:24 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">so how can i accurately measure it??</TD></TR></TABLE>
Caliper. Or a nice tape measure and calculate diameter from circumference, as above. Both should be accurate, and you can probably do a very good job measuring the circumference.
What's your margin of error in measuring the circumference? you said 7mm, could it be 6.8 or 7.2? If so, then you can't tell for sure what bar it is. Get an accurate measurement of circumference and you should be golden.
Old Jun 5, 2005 | 09:31 AM
.RJ's Avatar
.RJ
holla!
Old Jun 5, 2005 | 09:35 AM
Chris F's Avatar
Default Re: how to ID a ITR rear sway bar? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">holla!</TD></TR></TABLE>
And he made a molten sea, ten cubits from the one brim to the other: it was round all about, and his height was five cubits: and a line of thirty cubits did compass it about. (I Kings 7, 23)
Pi is 3, Bible says so.
Old Jun 5, 2005 | 10:21 AM
BLUE EH3's Avatar
Help we my pennies
let my measure again, rite now
Old Jun 5, 2005 | 10:22 AM
BLUE EH3's Avatar
Help we my pennies
7.2CM
Old Jun 5, 2005 | 10:24 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">7.2CM</TD></TR></TABLE>
[Shakes head] After this post it should be moved to GDD or just locked altogether.
Old Jun 5, 2005 | 10:26 AM
Chris F's Avatar
Default Re: how to ID a ITR rear sway bar? (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">
[Shakes head] After this post it should be moved to GDD or just locked altogether.</TD></TR></TABLE>
Yeah, I mean it doesn't take more than Google Calculator to tell you that 72/3.14159 is 22.92 mm.
-Chris
Old Jun 5, 2005 | 12:35 PM
BLUE EH3's Avatar
Help we my pennies
how can it be 22?
