zc sohc non vtec compression
Old Jun 4, 2005 | 08:00 PM
teamols's Avatar
Default zc sohc non vtec compression
i bought zc sohc non vtec from atarco, it's pretty old because it still has a fuel pump for a carburetor. it looks just like a d161a6, does anyone know any specs for hp and compression on this motor?
Old Jun 4, 2005 | 09:23 PM
dr_latino999's Avatar
Default Re: zc sohc non vtec compression (teamols)
So you purchased a carburated ZC? Hopefully Honda stayed cheap and kept the internals the same as usual which would mean you are at the standard 9.1:1.
Old Jun 5, 2005 | 09:29 AM
teamols's Avatar
Default Re: zc sohc non vtec compression (dr_latino999)
did they put it the rex or civ, throwing in p29's should not be a problem?
Old Jun 5, 2005 | 09:52 AM
Tyson's Avatar
http://www.honda.co.jp/HOT/Mod....html
its not quite the same as a A6. and i dont think it will produce you any more power. while probably the bottom end is the same, the cam is NOT the same as the 120ps MPFI ZC.
Old Jun 5, 2005 | 11:50 AM
civicflow's Avatar
Default Re: zc sohc non vtec compression (Tyson)
Are you positive the cam is not the same in the carb'd and mpfi version? My zc came from hmotors carb'd but I switched to mpfi. It will pull on any civic/crx w/d16. I was thinking it made less power because of the carb but I don't know. Any hard evidence the cam is different?
Old Jun 5, 2005 | 11:58 AM
Tyson's Avatar
Default Re: zc sohc non vtec compression (civicflow)
yeah im sure. ive dial indicated both. others have done the same with similar results.
maybe putting the carbed cam in the A6 will make more power. but the timing of the exhaust is off, duration is a bit different too for the carbed cam. the mpfi cam is exact same as A6 except the intake has a higher lift, but timing and duration is the same. so it just breathes better, along with the 4-2-1 exhaust manifold. ecu's are different too, but who knows whats (PR5) different than PM6.
its all revealed here.
https://honda-tech.com/zerothread?id=1186710
https://honda-tech.com/zerothread?id=1261845
Old Jun 5, 2005 | 07:11 PM
teamols's Avatar
thanks to all i have a z6 head i was hoping i would have enough compression to go with a mini me. it appears i would be right at 9.8:1. what do you think
AK94GSR
Sep 25, 2006 08:57 PM
Gant
10
Apr 29, 2004 05:26 PM
91hondacrx
89
Mar 13, 2004 08:40 PM
94eg4
Feb 6, 2004 07:32 AM
crx88fast
17
Aug 7, 2003 04:53 PM
