Min oil pressure for vtec?
Whats the min oil pressure for vtec to kick in? I went turbo and vtec does not kick in now and it takes some time to get passed 4000 rpm "more than when i was N/A!" what could it be? I think its oil pressure because when i put the turbo on the oil droped alot. its now 25 at idel and it uset to be at almost 85.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">85psi at idle?</TD></TR></TABLE>
Ya it was close to that at idel before the turbo instal. but only when cold, when hot i belive it was at like 40 but it will go up once you got to like 5K rpm. My car feels alwsome when i dont floor it. when i give it a little gas it starts to pick up fast but when i give it all the way it starts to die almost bog! iam running 7psi on a t3/t4 with intercooler and fuel is deliverd via 10 to 1 fmu. o ya its a bone stock jdm h22 with a jdm p13. plz help me out.
bringing this thread back to life .. what if oil psi is not at 57psi, what would you do to make vtec engage, or how would you bring up oil press ? Im boosted as well and vtec basically missfires like crazy when its supposed to engage.. I think oil pressure may be the issue
This sums up what causes low oil pressure.
http://www.aa1car.com/library/us1097.htm
What are your AFs ? What are you using to tune ? What is your oil pressure at while idling as well as with a load ?
MIKES
Jun 5, 2003 11:26 AM
