Octane Boost causing Check Engine Light???
Old Jun 4, 2005 | 02:58 PM
davidsco27's Avatar
Default Octane Boost causing Check Engine Light???
I have a '92 EX. I recently poured a bottle of Octane Boost into my tank to address a slight pinging problem and today, with the temps over 80 the check Engine Light came on for the first time. Also, the temp was running pretty hot on the highway. Could the additive be the culprit? And if so, did I do harm, and how can I correct?
Old Jun 4, 2005 | 03:01 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Octane Boost causing Check Engine Light??? (davidsco27)
Why use a bandaid? Have your timing checked. A stock engine shouldnt be pinging if you use the appropriate grade fuel. What octane did you have in the tank, and is your timing correct?
Old Jun 4, 2005 | 03:08 PM
davidsco27's Avatar
Default Re: Octane Boost causing Check Engine Light??? (jlacoy82)
Timing was done recently and is fine. Pinging has been coming on over the past year or so. The car does have 140,000. The Gas octane I have been using is 87. The worry now is the check Engine light. I am wondering if the additive is causing it, and if so if it is causing damage and how I can correct it.
Old Jun 4, 2005 | 03:15 PM
jlacoy82's Avatar
71.192.16.183
Nasty carbon deposits in the cylinder head? Hot spots? Have you tried some seafoam?
Old Jun 4, 2005 | 03:17 PM
davidsco27's Avatar
I'm not worried about the pinging now. I am worried about the Check Engine light and whether it was caused by the Additive.
Old Jun 4, 2005 | 03:34 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidsco27 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not worried about the pinging now. I am worried about the Check Engine light and whether it was caused by the Additive. </TD></TR></TABLE>
i seriously doubt it's the additive.most of those octane boosters only raise the octane one or two points(as in going from 87 to 87.2,not up to 89),if any.
what is the recommended octane grade for your car?have you tried running mid grade or premium?maybe recheck the timing,and even retard it a couple degrees as a temporary fix.
as said above,maybe carbon build up?Seafoam works wonders.
Chris
Old Jun 4, 2005 | 05:08 PM
Hapexamendios EJ8's Avatar
Default Re: Octane Boost causing Check Engine Light??? (TeamNextGenChris)
but that engine was made to use 87
Old Jun 4, 2005 | 05:14 PM
Default Re: Octane Boost causing Check Engine Light??? (Hapexamendios EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapexamendios EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">but that engine was made to use 87</TD></TR></TABLE>
i couldn't remember-it's been so long since i had a Z6 i wasn't sure.
Chris
Old Jun 4, 2005 | 09:17 PM
specv5150's Avatar
first of all......
WHAT IS THE CODE???
Old Jun 4, 2005 | 09:34 PM
Jim Truett's Avatar
Default Re: (specv5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">first of all......
WHAT IS THE CODE???</TD></TR></TABLE>
And it only took 8 posts
First, go here: https://honda-tech.com/zerothread?id=1171263
Second, Come back and tell us what code you have.
Old Jun 5, 2005 | 09:06 AM
davidsco27's Avatar
Default Re: (Jim Truett)
Code is 43
Old Jun 5, 2005 | 10:09 AM
nota-eg's Avatar
Default Re: (davidsco27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidsco27 &raquo;</TD></TR><TR><TD CLASS="quote">Code is 43</TD></TR></TABLE>
Ironic you added the Octane Booster and then get a fuel supply CEL. Anyone know how often fuel filters should be replaced? Mabe fuel pump is going, or clogged lines or a bad ground on the fuel pump?
Just throwing ideas out for you smart guys.
Old Jun 5, 2005 | 01:25 PM
davidsco27's Avatar
Default Re: (notabassist31)
That's why I was wondering if it was caused by the additive. Maybe overloading the O Sensor. The Fuel Filter isn't too old, I do them kinda regularly. Other suggestions are possible
Old Jun 5, 2005 | 01:37 PM
specv5150's Avatar
well check everything fuel related. I have used octance booster many times and never threw a code.....
Old Jun 5, 2005 | 01:50 PM
cnyej1's Avatar
If you were overloading the O2 sensor then you would get an O2 code. I believe that is a 1.
SLEEPIN-GSR
Jul 3, 2009 06:43 AM
iafrate
May 30, 2003 03:01 PM
Beast53568
Apr 12, 2003 10:14 PM
DeeperFOLK
Oct 11, 2002 01:36 PM
CWBETB
Oct 8, 2001 11:59 AM
