Sunroof Q?
Old Jun 4, 2005 | 01:24 PM
osideracer1's Avatar
Default Sunroof Q?
Wat up guys, I have a small sunroof prob. When i close the sunroof, the right side seems to get stuck for s split second and causes the sunroof to close at an angle. I tried cleaning the rails and re-lubricating them but it still does the same thing. Does anyone have a clue what could be causing this? Could it be the sunroof motor? Thanx for any info.
Old Jun 4, 2005 | 01:43 PM
sohcvtec1995's Avatar
Default Re: Sunroof Q? (osideracer1)
Most likely one of the many plastic things is broken, which is causeing this to happen.
Old Jun 4, 2005 | 02:26 PM
93_hatch's Avatar
i had this problem too but really bad it sounds like ur cables are getting worn.
the sunroof is run by a screw like cable the cables are about 170 from the dealer. best way to see if it is take the liner down and look at it
Old Jun 4, 2005 | 02:28 PM
Default Re: Sunroof Q? (93_hatch)
OMG 170. It would be cheaper to get a whole new sunroof assembly from a junk yard. Mine was 100 bucks, and has lasted 2 1/2 years.
Old Jun 4, 2005 | 04:29 PM
93_hatch's Avatar
Default Re: Sunroof Q? (sohcvtec1995)
yea i tried the junkyard but they look just as bad as mine
Old Jun 4, 2005 | 04:39 PM
thanx guys. im going to try to take the sunroof off to get a better look at what is happening. If it is those cables, then ill probably go the same route sohcvtec1995 did & go to a junkyard.
Old Jun 4, 2005 | 05:09 PM
2 Loe 4 Fat Hoes's Avatar
Default Re: (osideracer1)
i have a sunroof out of a 93 ex will give you a good price it works good i was going to use to put it on my dx but i sold my car so i just have it in my room ...anyways pmed send
raverx3m
Apr 12, 2016 08:59 AM
serr38
May 10, 2009 03:39 PM
NOFX
Oct 1, 2008 08:48 PM
94civicoupe
Dec 28, 2006 04:03 PM
KEVlN
Oct 4, 2001 07:47 AM
