speedometer went bad, lights went dim, now car doesnt start
Old Jun 4, 2005 | 10:22 AM
screen_name's Avatar
Default speedometer went bad, lights went dim, now car doesnt start
this is my friends 95coupe DX,
his speedo started jumping up and down,
then went to zero, then his lights went dim,
car started back firing now car wont start unles its push started
tried replacing the battery its not that any ideas?
Old Jun 4, 2005 | 11:30 AM
Default Re: speedometer went bad, lights went dim, now car doesnt start (LB562)
Old Jun 4, 2005 | 11:32 AM
d15bcoupe's Avatar
go to autozone and have them test the alt.
dewoine's Avatar
mines did the same thang about 3 weeks ago .turned out that the cable running to the alternator came loose ..check that out ..
Old Jun 6, 2005 | 04:50 PM
hybridmyk's Avatar
Don't mean to jack ur post, but i got a similar prob. One day, all my needles on my cluster just went dead. my whole cluster doesn't work. It lights up, n my battery light n srs light come on, but nothing else. My check engine light doesn't work. I purposely threw codes to see if my check engine light would come on, and it wouldn't. My blinkers don't work either. I dunno if i have gas, what the engine temp is, how fast i am driving or what. Tac doesn't work. I only kno where the rpm is at when I hit vtec. I checked fuses and took off cluster n then put it backon.
What do u guys think? Bad relay? Thanks.
Old Jun 6, 2005 | 05:12 PM
sammysnakes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dewoine &raquo;</TD></TR><TR><TD CLASS="quote">mines did the same thang about 3 weeks ago .turned out that the cable running to the alternator came loose ..check that out ..</TD></TR></TABLE>
check all the fuses in your engine bay fuse box and make sure the alternator wire isn't loose.
90DB1TegSedan
Sep 5, 2012 10:44 AM
quichocho89
Mar 27, 2010 10:12 AM
DB8_TEG
May 8, 2008 02:16 PM
OBDII Integra
Jun 3, 2005 09:45 PM
ShakesTheKlown
Jul 1, 2003 02:05 PM
