Cluster/Signal problems
Old Sep 5, 2012 | 07:47 AM
90DB1TegSedan's Avatar
Default Cluster/Signal problems
I have a 90 integra and everything worked good until this morning
i turned on my car and eveything was working
when i backed up got out to close my gate and when i got
back in i noticed that my cluster mini lights (like door light and the
seat belt light) werent working then as i drove on my rpm,and temp werent working
then when i went to signal left and right my turn signal wouldnt work
here at work i did a check on my fuses under the driver side and all were good
i dont know where to go from there
was told could be a cable and that i might not be gettn enough
cold amps
any help would be appreciated
Old Sep 5, 2012 | 09:07 AM
Navy_Kyle's Avatar
Default Re: Cluster/Signal problems
check the fuses under the hood too.
Old Sep 5, 2012 | 09:19 AM
kingteg's Avatar
^This. (Check your battery voltage as well.)
Old Sep 5, 2012 | 10:43 AM
The battery had actually died on me the day before and i had someone give me a jump
the only thing on my cluster that works is the mph and i believe the gas gauge
clock doesnt work either but i will see if battery is the issue
Old Sep 5, 2012 | 10:44 AM
I did and they are all fine the only one that is blown is yhe battery one but that one has been like that sonce i bought it
it has a B20B swap in it
Stunna MIKE
Feb 23, 2012 06:50 PM
ltran82
Nov 1, 2007 12:58 PM
themex77
Mar 3, 2007 01:17 PM
my92hondasucks
11
Jul 26, 2006 03:54 PM
I Gotta Question
Feb 20, 2004 03:55 PM
