Weird electrical problem..please someone help
Old Jun 2, 2005 | 07:21 PM
OBDII Integra's Avatar
Default Weird electrical problem..please someone help
ok this just strated about a coulpe weeks ago but it has only done it twice and the second time just happened about an hour ago.....ok well i was just at my friends house and i went to turn my car on and it wouldnt strat...lights and everything worked radio did 2...but my gaugue cluster for like my battery light and my check engine light would not turn on so the car wouldnt start....then al of asudden everything just cam eon and the car started fine and ran fine....at first.....then while i was driiving it the lights started to flicker and the car shut off...then it came back on....ran fine...then i put my rgiht turn signal on and as soon as i hit it the lights flickered again adn the car almost shut off then came back on...ne suggestions? also when i make my windows go up my headlights dim alot more than usual...and when i was trying to start it my headlights and my interior lights would flash light off then on...battery? alternator? i'm not sure i have never had this happen to me before..
Old Jun 2, 2005 | 07:53 PM
Default Re: Weird electrical problem..please someone help (OBDII Integra)
anyone?
Old Jun 2, 2005 | 08:07 PM
thaiphob's Avatar
Nikon!!!
Have you checked the battery?? autozone does free checks.
Old Jun 2, 2005 | 08:12 PM
Default Re: Weird electrical problem..please someone help (thaiphob)
I was thinnking the battery but if it was the battery would all my lights and everything else work? the only thing thats not working is the instrument cluster cehck engine light,oil light batttery light etc..
Old Jun 3, 2005 | 05:17 PM
anybody out there have any other ideas...this is just weird... i do have aem pullies could teh alternator pullie be making any of these porblems cause this rpoblem didnt really start until about a month after i put these on
Old Jun 3, 2005 | 05:54 PM
WhiteGSR95's Avatar
check your battery, other then that not much can be done without a wiring diagram. but u should check your battery, and alternator.
Old Jun 3, 2005 | 09:45 PM
Contender25
Guest
Posts: n/a
Alternator might be goin out, or battery, there both easy to get check/tested for free at autozone.
neilt
Honda Civic (2001 - 2005)
Mar 24, 2014 02:33 PM
daneek
11
Mar 1, 2010 11:31 PM
Samuels
Dec 14, 2007 03:45 AM
mystikteg92
Jul 8, 2004 12:17 PM
Sivic_Hatch
Apr 20, 2003 11:41 AM
