To the R owners with Nitrous, what gauges are you using?
Just as the topic states..
What gauges are you guys with nitrous on your "R" running?
That is excluding the nitrous gauge.
I am thinking of a greddy a/f, egt, water temp, oil press, and oil temp.
What do you guys think??
I have a wet kit now, and will be swapping soon. I have a triple pillar pod, and dash bezel, room for 5 gauges.
Another question has anyone be able to dremel a autometer (triple) 2-1/16 pod to fit a 60mm gauge?
Reason I ask cause I would like to install the greddy a/f (only comes in 60mm) and egt (60mm) in the pillar pod and put a 52mm gauge in the last opening.
And then put (2) 52mm in the bezel.
thanks
Eric
thanks
Eric
i just got the nos pressure guage on the bottle and then autometer oil press and a/f . . which is useless . very unaccurate
and the b&m fuel press on my fuel rail
Nitrous Pressure on the bottle, then nothing else and then it blew up and then I took off the Nitrous
how many times have u posted this already? just be patient
Why? I just asked a question?
And I am being patient??
Not understanding where you are going with this????
you got any parts you wanna sell . i need an ignition and some jets. . . also some nitrous lines.
im upgrading to wet kit now .
I want that one guage they had in F&F where your passenger floor board falls out if you are running too lean.
