main differences between series
Old Jun 3, 2005 | 10:26 PM
CaptivaBlue's Avatar
Default main differences between series
I asked this question awhile back in the EG forum, just to learn and got flamed- hard. I don't need to figure out which one is best for me, or which is better for what, this isn't about that. I just want to know what are the main mechanical differences between the B's and H's, other than the obvious like bore/stroke/cams... This is an engine theory question. I have no intention of putting an H in my Sol. I'm just curious why we have a B16A and a H22A4 and not a H16A4 or a B22A (old-skool Preludes excluded).
Old Jun 4, 2005 | 05:19 AM
NJIN BUILDR's Avatar
Default Re: main differences between series (CaptivaBlue)
B series were designed for lighter civics.For bigger cars like accords and preludes they needed a larger motor like the H's and F's.Not really sure why they went with the b20 in the crv and not a H.Honda makes decisions based on engineering requirements as well as money.Hope this helps
Glenn
Old Jun 4, 2005 | 06:51 AM
Default Re: main differences between series (NJIN BUILDR)
Are the block castings much different? I was under the impression that the H blocks were beefier (proportionally speaking).
Old Jun 4, 2005 | 09:19 AM
Yes,H and F's are physically bigger.
Glenn
Old Jun 4, 2005 | 09:49 AM
I know that, that's obvious. ... nevermind
Old Jun 4, 2005 | 10:26 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Not really sure why they went with the b20 in the crv and not a H.</TD></TR></TABLE>
The CRV is based on the Civic.
Old Jun 4, 2005 | 10:33 AM
z6's Avatar
z6
i was told that an H series is like a blown up version of a b18c
Old Jun 4, 2005 | 12:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptivaBlue &raquo;</TD></TR><TR><TD CLASS="quote">I know that, that's obvious. ... nevermind</TD></TR></TABLE>
If it was that obvious why did you ask?
Glenn
Old Jun 4, 2005 | 02:00 PM
What I want to know is the main reasons why there are different series. There has to be some mechanical differences I'd think to put them in different engine families. I know that the obvious stuff (displacement, cam specs, and such are different) but does one spin a different way? Is one made of a different material? Is one have a few distinct differences internally? That sort of thing.
Old Jun 5, 2005 | 04:40 AM
The B's and H's are very similar designs although not interchangeable.They rotate in the same direction,and have similar camshaft,rocker and timing belt layouts.They use the same materials for blocks heads and cranks.They both have cast pistons and forged cranks and rods.The B's have cast iron cylinder sleeves but the H's have a composite liner that isn't compatible with forged pitons.The H's use a cable to shift the tranny and the B's use rods.
Glenn
Old Jun 5, 2005 | 05:09 PM
Cool, thanks. That was the type of stuff I was after, anyone else?
DJ_SaNdOz
Aug 31, 2006 08:49 PM
b16aef4dr
10
Apr 9, 2006 12:02 PM
HELLAnorcal
Jan 24, 2006 07:11 PM
NaturalyAspirated
Nov 30, 2005 02:19 PM
Eyes Only
Jan 25, 2004 06:44 PM
