Tie bar needs longer bolt? shit!
sup,
i have a 00 si and i bought a used tie bar (tenzo R) for only 40 bucks. im not looking for an excellent suspension system..im mainly into the street performance set up. anyways i was going to put it on and then thought for a moment about the bolts. am i going ot need to go to a nuts and bolts shop to get a bigger bolt that way there is room for the tie bar to fit or is the bolt bit enough? thanks
You waited exactily 1 minute before bumping your post. Be patient. And, you should be able to use your stock hardware, assuming it mounts to a factory point.
civicdohc
Dec 31, 2003 06:55 PM
