OEM Fogs lights to dim, why??? PLEASE HELP
Guys I have a problem with my fog lights, there to dim compared to others that I have seen, any suggestions of how to correct it?? Please HELP, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon_LS »</TD></TR><TR><TD CLASS="quote">I thought about it, I just wanted to know could it be anything else before I buy them, what wattage do you recommend?</TD></TR></TABLE>
if they are oem you will see the watts and type on the fog lights housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon_LS »</TD></TR><TR><TD CLASS="quote">I bought the car with them installed, </TD></TR></TABLE>understood, but where they installed from the dealer? or by the previous owner? or just some dude? if it wasnt installed from the dealer it might help you to find if its a loose wire or something. hell even it it was installed from the dealer there could be a weak ground, or whatever. you could need brighter bulbs also. how is the progress btw? did you check into brighter bulbs? i have an 94 hatch and my fogs are 55watts and brighter than my headlights, even thought they are 60.
I had the same problem so i did this
IS300 Foglights retro'd onto Eg brackets mounts up like it was from the factory
Note these are using factory 35w bulbs. im gonna experiment with some high wattage bulbs for different results.
new pix
new pix
holy crap, ecu guy, thats awesome
when my bulbs go out im doing that, it looks really really good. do you have a diy for that somewhere??
i technically dont consider it a thread jack since it is slight guidance on how to make his lights brighter.
14 hours is a lot. did you use washers to aim? any pointers to save time/effort?
Nope everything is molded onto the brackets. other brackets were made and added on and just kept test fitting and aiming. til i got it perfect. then i Jb welded everything in place.
Hi SPOON LS,
I recommend you stay with a 55 watt or 85 watt bulb on your stock wiring, You can always step up to a 120 watt bulb with the correct lamps and harness to handle the power! PIAA has all different types of bulbs from 55 watt to 120 watt.
Check out our web site- http://www.PIAA.com
Let me know if I can help you out with anything else!! - Brock
hey look at my signature.
Dammm JDMlyfestyle 14-16 hours.
Dammm.
Using the lamin-x is a easy way and it take less time to complete it compare to cutting the bumper.
Dammm.Using the lamin-x is a easy way and it take less time to complete it compare to cutting the bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">hey look at my signature.
Dammm.
Using the lamin-x is a easy way and it take less time to complete it compare to cutting the bumper.</TD></TR></TABLE>how does it make them brighter????
Dammm.Using the lamin-x is a easy way and it take less time to complete it compare to cutting the bumper.</TD></TR></TABLE>how does it make them brighter????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleh »</TD></TR><TR><TD CLASS="quote">how does it make them brighter????
Different bulb.
Btw did you check you light fuild, maybe you need to refill. LOL
</TD></TR></TABLE>Different bulb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">Different bulb.</TD></TR></TABLE>there you go, the lamin-x does nothing for brightness, all show.
well guys, i didn't have internet for a few days, and I just started a my summer classes but as soon as I can check the wire harness I let everybody, thanks a lot for the help, anything else that you might think just let me know
sno83oky
Dec 14, 2003 08:25 AM
