Need help with timing!!
Old Jun 3, 2005 | 01:51 PM
1bar_ek's Avatar
Default Need help with timing!!
I just put my head + turbo back unto my car. Turned on the car, but the engine doesn't seem like it wants to turn and fire up. Timing belt and cam gears seems to be moving really slow. I believe my timing is off, and or my engine is not at TDC.
Can anyone help???
Old Jun 3, 2005 | 05:29 PM
Suck my DX's Avatar
Default Re: Need help with timing!! (darkside_ek)
what kind of motor u runnin
Old Jun 6, 2005 | 11:01 AM
1bar_ek's Avatar
Default Re: Need help with timing!! (Suck my DX)
b18c1
Old Jun 6, 2005 | 11:08 AM
HoUTX98GSR's Avatar
check the firing order... make sure you got your plug wires right.
Old Jun 6, 2005 | 07:24 PM
Suck my DX's Avatar
well if u want a quick check to see tdc..pull out ur #1 spark plug and take a long screwdriver or whatever and lower it in there so it rests on the piston...now turn ur crank ccw until the screwdriver wont go any higher...thats tdc...also on your crank pulley there is a set of 3 lines...and a little off to the side from those lines there is a single line may or may not be painted white...that should line up to the white line on ur timing belt cover...make sure that ur cam gears are not flipped 180 ....that way u can tell if ur timing is off as well...hope that helps..let me know how that goes
Old Jun 8, 2005 | 07:13 PM
blacksihatch's Avatar
ive got the same problem with my motor b16 and the cams when i removed them i never took the stock gears off and the motor is TDC and the white matrks on the pulley is matched up to the valve cover even with the cams pointed up and the marks all aligned there no way it can be 180 degrees off ...right??
because my **** keeps turning and turning with no hint of firing up.....
Old Jun 8, 2005 | 07:21 PM
Suck my DX's Avatar
Default Re: Need help with timing!! (blacksihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksihatch &raquo;</TD></TR><TR><TD CLASS="quote">ive got the same problem with my motor b16 and the cams when i removed them i never took the stock gears off and the motor is TDC and the white matrks on the pulley is matched up to the valve cover even with the cams pointed up and the marks all aligned there no way it can be 180 degrees off ...right??
because my **** keeps turning and turning with no hint of firing up..... </TD></TR></TABLE>
im pretty sure that the intake cam wont go into the dizzy 180 wrong way......and if the in. is in right then it should be a cinch to alighn the ex. one...i dunno my motor started after about ten cranks...runs beautiful..
Old Jun 8, 2005 | 07:34 PM
Well the car was sitting for 3mo with nearly an empty tank so i wonder if it bad gas so i put another 2 gallons in because thats the biggest tank i've got and maybe my spark is alittle weak so im going to change the coil and upgrde the plug wires( they need it ) and cross my fingers
Old Jun 9, 2005 | 06:12 AM
1bar_ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">well if u want a quick check to see tdc..pull out ur #1 spark plug and take a long screwdriver or whatever and lower it in there so it rests on the piston...now turn ur crank ccw until the screwdriver wont go any higher...thats tdc...also on your crank pulley there is a set of 3 lines...and a little off to the side from those lines there is a single line may or may not be painted white...that should line up to the white line on ur timing belt cover...make sure that ur cam gears are not flipped 180 ....that way u can tell if ur timing is off as well...hope that helps..let me know how that goes</TD></TR></TABLE>
Thanks for the help. I'll try this to see what happens.
jdm4alifetime
Nov 25, 2014 07:11 AM
shark13
19
Sep 23, 2012 11:21 AM
tpnorth
Jul 18, 2011 07:30 PM
Kwuaymaikrup
15
Mar 8, 2004 06:43 PM
redcrx1
Nov 29, 2003 06:40 AM
