engine noise??? whats the prob????
Old Jun 3, 2005 | 11:34 AM
Honda_Cribb_GS-R's Avatar
Default engine noise??? whats the prob????
i have a 97 coupe wit a b18c1 swap and the motor is making a ticking noise dont know what its is, a friend said get valve job done, (im also bout to put new timing belt and water pump on hopefully that might fix it ) but i have a cousin with a 00 integra gsr and his doesn't make a ticking noise help me if ya can!!!
Thanks
Old Jun 3, 2005 | 11:58 AM
mike1114's Avatar
Default Re: engine noise??? whats the prob???? (Honda_Cribb_GS-R)
well...do the valve job then. See if the ticking goes away.
Aftermarket larger injectors tick loudly also.
Old Jun 3, 2005 | 12:02 PM
9_of_10's Avatar
Default Re: engine noise??? whats the prob???? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">well...do the valve job then. See if the ticking goes away.
Aftermarket larger injectors tick loudly also.</TD></TR></TABLE>
Probably just needs the valve job. Try that before spending the money for the timing belt and water pump. Unless you want to do those things now.
Old Jun 3, 2005 | 03:27 PM
Default Re: engine noise??? whats the prob???? (9_of_10)
ok cool thanks ill do the valve job and the water pump and timing belt (already bought them) (oem water pump & greddy timing belt )
Old Jun 6, 2005 | 05:12 PM
Old Jun 6, 2005 | 06:08 PM
mrlegoman's Avatar
Have you over-reved it lately? Could be a 'bent valve' tick......
pityocamptes
Apr 22, 2011 12:40 PM
VeeTech Lude
Jun 25, 2005 08:48 PM
DC2*Integra
Apr 3, 2004 04:14 PM
quickLSt
Jul 24, 2001 07:14 AM
