Clutch help
Old Jun 3, 2005 | 09:45 AM
st95accord's Avatar
Default Clutch help
So i got my h22 going and it's started but the clutch pedal when pushed down just stays down on the floor board... Is this just a bleeding problem?
Old Jun 3, 2005 | 11:48 AM
devilpuppy's Avatar
Default Re: Clutch help (st95accord)
i dont believe so, when that happened to my 96 accord
the clutch master cylinder had to be changed
if you look at the clutch pedal, there will be a rod attached to it that goes through the firewall, if you see a leak there, that means the clutch master cylinder must be replaced
Old Jun 3, 2005 | 12:06 PM
NAiL05's Avatar
If ur master cylinder and everything is full it could be a bleed problem. If not u got something leaking and u will have to replace the component usually the master cylinder and u could check it like what devilpuppy said.
Old Jun 3, 2005 | 02:47 PM
deserthonda's Avatar
chk the slave cylinder as well if it leaks you get same problem
Old Jun 3, 2005 | 04:27 PM
st95accord's Avatar
Fixed... just needed to be bled a little more.
SWAP IS COMPLETE. and running very well
vinceg143
Sep 9, 2008 07:14 AM
crxricer66
Dec 1, 2007 07:58 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
majinx4
Jun 14, 2006 05:46 AM
thenick
12
Nov 28, 2004 01:35 AM
