99 Civic aftermarket radio in lower Din
Old Jun 3, 2005 | 09:36 AM
dawrenn's Avatar
Default 99 Civic aftermarket radio in lower Din
What do I need to put an aftermarket radio in the lower din on a 99 Civic?? What are all the parts that I need?
Old Jun 3, 2005 | 09:45 AM
civictildeath's Avatar
Default Re: 99 Civic aftermarket radio in lower Din (dawrenn)
well, if you have keyless entry, you need 3 harnesses (best buy) (need these to keep keyless entry), the stereo, and the metal jacket that comes with the stereo.
Old Jun 3, 2005 | 09:57 AM
dawrenn's Avatar
Default Re: 99 Civic aftermarket radio in lower Din (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">well, if you have keyless entry, you need 3 harnesses (best buy) (need these to keep keyless entry), the stereo, and the metal jacket that comes with the stereo.</TD></TR></TABLE>
I alread have an aftermarket radio installed and keyless entry works. I want to put it where the cup holders are. I was told I need a 96-98 civic cup holder but I am not sure what other parts I need.
Old Jun 3, 2005 | 10:05 AM
sohcvtec1995's Avatar
thats only with the first gen ek (96-98)
as far as moving the radio down below, you will not be able to use parts from the first gen ek because the dash lines are different. you should just have to cut some area off, and make a new bracket. May i ask why u want to move your radio down there?
Old Jun 3, 2005 | 10:07 AM
Black_SiR's Avatar
Default Re: 99 Civic aftermarket radio in lower Din (sohcvtec1995)
heres the link for all you need my friend:
http://www.jimmmmmmmah.com/Ins...N.htm
Old Jun 3, 2005 | 10:08 AM
pdiggitydogg's Avatar
96-98 cupholders
You may have to extend some wires...I dont know for sure.
To do it right, you'll also need
77297-S04-000ZZ BRKT, L. FR. CONSOLE
77296-S04-000ZZ BRKT, R. FR. CONSOLE
Both are like $17ea
They hold the unit in place...I didnt use them.
The reason mine is there, is so I can put gauges in the upper din
Old Jun 3, 2005 | 10:25 AM
dawrenn's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
as far as moving the radio down below, you will not be able to use parts from the first gen ek because the dash lines are different. you should just have to cut some area off, and make a new bracket. May i ask why u want to move your radio down there? </TD></TR></TABLE>
So it will be harder to see that I have a cd player.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">96-98 cupholders
Both are like $17ea
The reason mine is there, is so I can put gauges in the upper din</TD></TR></TABLE>
If I get this: http://cgi.ebay.com/ebaymotors...&rd=1
What will I need besides the bracket? Will I still need the radion surround?
Old Jun 3, 2005 | 10:29 AM
just the brackets
You'll just be removing the cd deck (see last pic on ebay) and inserting your own.
On mine, I had to do some filing to make the insert fit...but that wasnt a big deal
Old Jun 3, 2005 | 10:38 AM
screwcitycoupe's Avatar
I have my Alpine in the lower din on my 98. I didn't have to use anything other than the wiring harness to hook it up. You may need an extender for your antenna lead, but probably not. I didn't hook mine up as I never listen to the radio.
The only problem I have with it is the cup holder cover won't open all the way and some drinks don't fit all the way anymore. I plan on fixing this, but it's not a high priority.
Old Jun 3, 2005 | 10:56 AM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">just the brackets
On mine, I had to do some filing to make the insert fit...but that wasnt a big deal</TD></TR></TABLE>
What if I get this one: http://cgi.ebay.com/ebaymotors...&rd=1 is it the samething without the radio? The reason I would want this one is it looks like it is in better shape than the other one.
Old Jun 3, 2005 | 10:58 AM
Hard to say...I cant tell if its missing the surround or not. The din pocket is definately not there.
Ask him
Old Jun 3, 2005 | 11:02 AM
dawrenn's Avatar
Is the din pocket what the radio is in on the first Ebay link?
Old Jun 3, 2005 | 11:05 AM
No, its just a pocket that is there stock, if there is no cd deck
Old Jun 3, 2005 | 11:12 AM
dawrenn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">No, its just a pocket that is there stock, if there is no cd deck</TD></TR></TABLE>
I know what your talking about. I guess I will get the first one. If there are scratches they probably can be removed somehow.
Travis2262
Jun 15, 2007 08:43 PM
SLATER97EX
Jan 27, 2007 11:05 AM
EK k kay
Audio / Security / Video
Apr 5, 2005 11:23 AM
JoeCDN
13
Jun 18, 2004 08:47 PM
sinotataymo
10
Jun 9, 2003 09:25 PM
