What can I do about a P1300 CEL?
Old Jun 3, 2005 | 06:41 AM
crxhybrid85's Avatar
Default What can I do about a P1300 CEL?
JDM H22a, converted to run OBD2. I'm using a 96 P13. Finally thought I had the car ready to pass inspection and I'm still throwing random misfire codes. I don't get it because the car drives great. I get the four codes for each cylinder plus P1300 which is something like "manufacturer control, ignition system"
Plugs/cap/rotor/wires are all new, so is this something in the distributer?
Old Jun 3, 2005 | 09:57 AM
RDN's Avatar
RDN
Default Re: What can I do about a P1300 CEL? (crxhybrid85)
injectors, fuel filter/pump/pressure, coil, maybe.
Old Jun 3, 2005 | 10:06 AM
Default Re: What can I do about a P1300 CEL? (RDN)
I think I may have figured it out. Turns out that obd1 injectors are 345cc, and obd2 are 290cc. I'm still running the obd1 injectors, so it's gotta be running a little rich using the obd2 ecu right?
It runs great with either the obd1 or obd2 ecu, but only throws a code on the obd2.
Doesn't seem to drive any diff with one ecu from the other, and no smoke or anything either.
How can I check the coil and the igniter to see if they are bad? Do they commonly go bad?
Old Jun 3, 2005 | 01:22 PM
PrettyLude's Avatar
ignitors go bad all the time
flash0124
Engine Management and Tuning
Oct 19, 2012 08:32 PM
my96GSRteg
Apr 15, 2011 11:07 AM
crxhybrid85
Aug 2, 2005 09:47 AM
Bimmerman
May 25, 2005 02:16 PM
